Sonotube sub build x2 18hz (Peerless) - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 82 Old 01-13-11, 08:16 PM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: Sonotube sub build x2 18hz (Peerless)
Or just get some nice KRK's or other depending on budget that will fit your shelves and then you have a studio monitor setup with a bit more bass. LOL
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #72 of 82 Old 01-13-11, 09:05 PM Thread Starter
BuddahX's Avatar
Mikey
the desk itself is going to have its own feet. this is just a ruff sketch. and the tubes arn't going to be actualy hooked up to the table. I'm cutting the table so they sit half way in and I'm going to run a rubber strip to seperate so I don't go chasing my mouse while gaming lol.
BuddahX is offline
post #73 of 82 Old 01-13-11, 09:09 PM Thread Starter
BuddahX's Avatar
Mikey
Yea I'm going to use the same Subs and amps. I'm going to hook up my two Alesis Monitor 2's with them. power them with a 2 ch amp. pretty much what I have on my HT setup now. then I'm going to focus on building two Line aray's for my HT and TC sound subs with PR's. I'm going to be re doing my whole man cave / Bedroom / loft lol.
BuddahX is offline
post #74 of 82 Old 01-13-11, 09:17 PM
chrapladm's Avatar
Papi
TLA, SLA, or CBT?
Just curious what you were thinking of for your line array not to say the CBT is one just added that in the mix.
post #75 of 82 Old 01-13-11, 09:23 PM Thread Starter
BuddahX's Avatar
Mikey
I don't know now lol. I am def not a speaker builder. I've always been DIY subs. and from what this guy is saying I should stick with already designed DIY kits. Do you have any suggestions on what type of towers. they don't have to be line array's. I just thought they would sound good. My budget is around 800 total.
BuddahX is offline
post #76 of 82 Old 01-13-11, 09:37 PM
chrapladm's Avatar
Papi
Just honestly depends what you want.....all ears are different.
I have some BFM SLA's for now. I have the parts to make some E-waves but I am also getting ready to make a CBT center channel. I have lots of plans of Klipsch designs also that someday I will build but for now I just have my very friendly budget wise SLA's. My surrounds are not done yet either but they are just a small pair of E-waves using the JBL 6" drivers and selenium CD.
But like I said everyone likes different things.
I cant remember if it was MKtheater or not but someone on this or "the other," forum have massive JBL clones , I believe, for there L/C/R.
Oh and I am definitely NO speaker builder myself. I am getting better but would never sell my stuff to anyone. But its fun making stuff that atleast I can say I built. Although sometimes I would rather not say.
post #77 of 82 Old 01-15-11, 09:02 AM
chrapladm wrote: View Post
I would love to do something like that but I dont think I will be able to afford an option like that. But even if I could I would have to put some sort of metal grille or metal flyscreen around the "pillar supports," to keep little fingers out.
And did anyone ever tell you, you needed to add nails to the outside into the endcap?
Just wondering because I am going to be starting my build in the next month.
Are you needing to be able to remove the end cap later? If not, you would be using adhesive and would need zero screws or nails...or at most a couple in there if you were worried about holding it in place while the glue dries.
vitaminbass is offline
post #78 of 82 Old 01-22-11, 11:30 PM Thread Starter
BuddahX's Avatar
Mikey
Here is some work. Got the table up, and started on the glass pieces. had to go to my sister company and make two more pieces of glass. I used brass feet for spacers just to show the look I'm going for. I will be using rods for spacers.
BuddahX is offline
post #79 of 82 Old 01-23-11, 02:26 AM
chrapladm's Avatar
Papi
Wow ...I will be using an acrylic piece for my top plate. I will have to follow your leg supports for the glass piece.
I dont know what height to use until I do some testing. So I will try and use three different leg heights to hopefully get the correct height.
Did you just glue your legs on for the glass support?
post #80 of 82 Old 01-23-11, 06:11 PM Thread Starter
BuddahX's Avatar
Mikey
I havnt fully put them on yet. Still debating what to do. More than likley use black 100% silicone to keep them in place. It will stick to the glass good and if i have to i can use a razor to take them off. I am very pleased with the look. Im holding off cause i might frost the glass and put some blue led's on them so they glow for the finishing touch. Im already designing new subz for my HT setup n these are now for my computer lol. Its hard for me to sit back and not build stuff. Lol
BuddahX is offline
18hz , build , cuft. , sonotube
