Dual RL-P18 LLT for my 2000 cu ft HT soon - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 183 Old 06-02-07, 02:43 PM Thread Starter
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
Re: Dual RL-P18 LLT for my 2000 cu ft HT soon
I think that any porosity in MDF might be negligeable. But Plywood really seems stronger but at least double cost!!
Blaser is offline
post #52 of 183 Old 06-02-07, 02:48 PM
Paul
Actually, the amount of breathing that an untreated MDF cabinet with veneer, or some other nice finish on the outside does seems like it would be so minimal as to be meaningless compared to the dynamic changes of pressure induced by a subwoofer. I only paint the inside as a "belt & suspenders/chicken soup" type of approach, in that it doesn't cost much, and it may actually help seal any place I miss with glue & caulking.
I certainly wouldn't call it hermetically sealed, unlike Carnac the Magnificent's mayonaise jar kept on the front porch of Funk & Wagnall's house.
Paul
aceinc is offline
post #53 of 183 Old 06-02-07, 03:02 PM Thread Starter
Blaser's Avatar
Ahmed
FOR THOSE INTERESTED IN THE RL-P18 TESTING BY ILKKA, THEY ARE WELLCOME TO CHECK THIS:http://www.hometheatershack.com/foru...html#post38201.
I AM POSTING THIS HERE AS ALTHOUGH IT MAKES SOME TIME ILKKA HAD PROPOSED TO TEST THE WOOFER (AS FAR AS DONATION WOULD COVER THE DRIVER FEES), I JUST NEW TODAY, AS I WAS ONLY LOOKING AT THIS DIY FORUM....SO MAYBE SOME OF YOU JUST DON'T KNOW!
Blaser is offline
post #54 of 183 Old 06-02-07, 03:26 PM
According to the modelling softwares, lining the walls does not change the tune but slightly the FR...Anything wrong with it?
I don't think it's bad, it's just that stuffing changes the effective size of the box. I think you can calculate that size change and alter your box size in the modelling software and see what happens.....
brucek is offline
post #55 of 183 Old 06-02-07, 03:33 PM Thread Starter
Blaser's Avatar
Ahmed
brucek wrote: View Post
Insulation is supposed to make the box appear bigger, not smaller....That's the issue: How larger??
Blaser is offline
post #56 of 183 Old 06-02-07, 05:16 PM Thread Starter
Blaser's Avatar
Ahmed
Cables now...What gauge is required to support 2000 W? Is 16 enough
Blaser is offline
post #57 of 183 Old 06-02-07, 06:22 PM
Well, I'd use 12 or 10 gauge...........
brucek is offline
post #58 of 183 Old 06-02-07, 10:33 PM
planet10's Avatar
Dave
blaser wrote: View Post
Thank you for your post , I just need some clarifications pls
What do you mean by dead center?
Do not put a brace exactly in the middle of a panel. A more general statement is that any brace should not divide a panel into 2 (or more) identical sub-panele.
How? Pls elaborate, Do you mean that not stuffing would be acceptable?
As far as the frequencies a sub should be producing, damping has no effect. It will thou increase the appartent size of the box. I would not trust a modeler (except maybe MJK within linits) to account properly for the stuffing.
dave
No matter where you go, there you are.
planet10 is offline
post #59 of 183 Old 06-02-07, 10:37 PM
planet10's Avatar
Dave
And what proportion of the total cost is that compared to the cost of the driver(s) and the effort you are putting into it?
Unless you are somewhere where the price of wood is out-of-site (ie BB in Western Australia), arguing about the difference in cost of panel material is penny-wise, pound foolish.
dave
planet10 is offline
post #60 of 183 Old 06-02-07, 11:19 PM
Paul
This is what I meant by a religous war...
Some people belive that the mass and uniformity of MDF makes for a better speaker, others believe the strength of BB is better and there are even a few lost souls that believe particle board is best. I have been unable to find a definitive answer by someone that has done empirical, objective testing, and until I do, I will use plywood and MDF interchangeably, as in the speakers I am currently building that have a bit of both.
I have thought a little about a test regime. If I can get around to it what I thought I might do is take a driver (I have some HiVi A5+ 5" drivers laying about) build two cabinets that WinISD says is an optimal for sealed with a 1-1/4" MDF baffle. One cabinet would be 13 ply BB and the other MDF with veneer, braced as similar as I can make it. For testing I would;
1) Do freq tests measuring from one meter on axis, and set amplifier for a reasonable level such as 85db.
2) place the mic face down on each of the panels coupling the mic to the panel, and run the same tests.
3) place the mic about 1-2mm away from each panel and re-reun the above tests.
What I would hope to find is if there are any differences.
Paul
aceinc is offline
2000 , cu , dual , ft , ht , llt , rlp18
