What i discovered in my LLT build - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 47 Old 04-27-07, 12:32 PM
thxgoon's Avatar
thxgoon
Re: What i discovered in my LLT build
Wow, that is a cool review. Has he reviewed other amps as well?
I got my info regarding efficiency from this thread
http://forums.audioholics.com/forums...ad.php?t=14222
I too would like to know how it is possible to pull so much power from the wall dispite the fuses. Maybe because of the 50% duty cycle the fuses never got hot enough to trip???
thxgoon is offline
post #32 of 47 Old 04-27-07, 12:36 PM
Will
Send a message via AIM to WillyD Send a message via Skype™ to WillyD
I dunno about the fuses, but acheiving the full power output at 1kHz is quite irrelevant with regards to maximum output at say, 20Hz.
WillyD is offline
post #33 of 47 Old 04-27-07, 12:52 PM
thxgoon's Avatar
thxgoon
WillyD wrote: View Post
The review found the 2500 to output 2112W bridged into 4ohms at 20hz. The sine wave shows virtually zero distrotion as well.
thxgoon is offline
post #34 of 47 Old 04-27-07, 01:38 PM
Will
thxgoon wrote: View Post
Right, and that proves my point. At 20Hz, the output capability had decreased by ~12%. Am I right?
WillyD is offline
post #35 of 47 Old 04-27-07, 01:58 PM
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
Yes, that's normal... Bruce once expected that!! But I would appreciate that he clarifies how that is possible with a 15 A fuse...
Blaser
Blaser is offline
post #36 of 47 Old 04-28-07, 10:22 AM
Slow blow fuse is used on the primary side. The 2500 watt rating (on the load side) is possible only short term, relying on the power supply capacitors to supply the current for those bursts.
You can't support 2500 watts for long on a 1800 watt circuit (obviously). Generally the line will sag below 120 volts when attempting to dissipate 2500 watts for long. The real source of the problem is revealed when the poster says:
However i also think one of my main problems is voltage drop as every time it hits the lamp next to me dimms a good amount. I dot have the setup very good at all with my arcam, cd player, and the EP2500 all on the same outlet..
hehe, that dimming light is telling you something. The power supply in the 2500 can supply current from its capacitor reservoir. You need to fill the well with a decent line to have a fighting chance. The problem lies in the supply side, not in the amplifier....
brucek is offline
post #37 of 47 Old 04-28-07, 11:09 AM
Blaser's Avatar
Ahmed
Yes Brucek, this is well understood, but this is not the fault of the amp.... This will be the same for any amp. What I am concerned about is :assuming there is no line sag, the amp can deliver 2112 W RMS into 4 ohms bridged at 20 Hz, and 2400 W at 1 KHz as per the reviw. Is this possible with a 15 A fuse?
When you say:"The 2500 watt rating (on the load side) is possible only short term, relying on the power supply capacitors to supply the current for those bursts." does it mean it is only peak power??
The review was clearly saying that it was 2112 W RMS (assuming no line sag). Pls re-check.
From the other side, pls check this AVS thread http://www.avsforum.com/avs-vb/showt...9&page=2&pp=30 where thylantyr says "there is amajor flaw in the test"!! But wouldn't say what this flaw is about unless PMed.
Any comments?
Blaser
Blaser is offline
post #38 of 47 Old 04-28-07, 12:20 PM
Sure, for a short period. Note in the test he used a 50% duty cycle.
Nope, RMS power, if you kept the line at 120volts and for short cycles.
Didn't read the thread, but I'm sure the flaw is that it isn't continuous RMS power into a load over 20Hz to 20000hz........ how could it be. 1800 watts IN and 2500 watts OUT..can't be done for long.
brucek is offline
post #39 of 47 Old 04-28-07, 12:38 PM
Blaser's Avatar
Ahmed
I do not see where it is said 1800 Watts in?? So does this review tell us something obvious, i.e what if there was a 4000 Watts power from the wall? Would it probably achieve 2400 W continuously?
In a nutshell does this review tell us how well the EP-2500 meets its specs?
Blaser
Blaser is offline
post #40 of 47 Old 04-28-07, 01:02 PM
Standard 15 amp household circuit.
120 volts x 15 amps = 1800 watts........................
Yep, it meets its spec and is an excellent bang for the buck. Especially when we aren't that concerned about THD as in a subwoofer application. Same as the BFD...it's great for the application.
brucek is offline
build , discovered , llt
