LLT tempest x2 build - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 04-19-11, 06:13 PM Thread Starter
Ok i have decided to go for a tempest sub as outlined in the application notes by kevin Haskins.
this is the detail i have llt 340 lt or 12 cu/ft
tuned to 12 hz
no hp filter 50pc fill
port 152mm dia or 6 inch x 88.1cm long
shown as sonotube [20 inch x 72 inch] but i will build with mdf approx 24" x 24" x 42"
external.
powered by ep4000
my questions are........is the volume critical? ie if it ends up between 12-13 cu/ft will that have a bad effect?
........is a half inch port radius ok and how is the port and radius length maesured, ie outside
end to outside end. what do you think? thanks in advance
jeffpr is offline
post #2 of 11 Old 04-19-11, 09:25 PM
GranteedEV's Avatar
Kick logic 2 da curb
Re: LLT tempest x2 build
jeffpr wrote: View Post
yes, it affects both sound quality and extension to have the appropriate volume. For a tempest that is probably around 385L I think.
GranteedEV is offline
post #3 of 11 Old 04-19-11, 09:29 PM
Mike P.'s Avatar
Mike
a 6" port tuned to 12 hz would be 100.3 cm long. Port air speed won't be a problem.
A 13 cu.ft box with the same length port would be a 11.5 hz tuning.
A 3/4" round over would be better. A straight tube with a round over that is measured end to end is close enough for your tuning frequency.
600 watts will take the sub a bit past Xmax, you have enough power with a EP4000 for 2 subs.
We're all in this together!
Mike P. is offline
post #4 of 11 Old 04-20-11, 05:40 AM Thread Starter
Mike P. wrote: View Post
i am using one channel of the 4000 ,ie 650w approx into 4ohm. a smaller amp, ep1500 costs 80p/c of the 4000 but the ep4000 allows me to add another sub later. jeff.
jeffpr is offline
post #5 of 11 Old 04-20-11, 05:43 AM
Mike P.'s Avatar
Mike
I like the way you think!
How big is your HT room?
Mike P. is offline
post #6 of 11 Old 04-20-11, 03:50 PM Thread Starter
4.5 x 6.7 mt room with 2 2ft cubed sealed tempests powered by an ep4000.
do you know the enclosure volume of a tempest driver?
do i need protection against over excursion or just careful use of volume control?
thanks in advance. jeff
jeffpr is offline
post #7 of 11 Old 04-20-11, 08:20 PM
Mike P.'s Avatar
Mike
With one channel powering the sub you'll be fine.
Mike P. is offline
post #8 of 11 Old 04-21-11, 07:00 PM Thread Starter
any idea of how much volume a tempest driver takes up in an enclosure ? ie 0.5 cu/ft?
thanks. jeff.
jeffpr is offline
post #9 of 11 Old 04-21-11, 08:57 PM
Mike P.'s Avatar
Mike
I forget. Contact Exodus for the information.
Mike P. is offline
post #10 of 11 Old 04-21-11, 09:06 PM
dboff01
According to the Exodus data sheet for the Tempest-X2, it occupies 0.18 cf.
dboff01 is offline
build , tempest
