IXL 18.2.2 HT Build (10.0 cu ft 15hz) - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #71 of 79 Old 12-28-11, 09:55 PM
Bubba
Re: IXL 18.2.2 HT Build (10.0 cu ft 15hz)
Nice! How many decibels does adding an additional driver add? And is that if you put the same amount of power to it, also?
black_z is offline
post #72 of 79 Old 12-29-11, 02:31 AM
gperkins
If the sub is stacked on top then adding a second sub should yield you a 6db increase although it could be less. So try and imagine with Gregg's as he has two identical subs stacked. I would love to see some sweeps of 1 sub then add the second followed by the third and fourth. Just to see the results.
How about it Gregg? Have you managed to run any sweeps yet?
My subs are co-located and I notice quite a big difference to my ear by adding the second sub and there is less need for EQ'ing as I get a much flatter response. The bass doesn't sound so located as it did with one sub.
gperkins_1973 is offline
post #73 of 79 Old 12-29-11, 08:44 AM
Bubba
I see. What happens if you run the same amount of power, but to two subs versus one? What is the gain then?
black_z is offline
post #74 of 79 Old 12-29-11, 08:47 AM
Drizt's Avatar
Drizt
black_z wrote: View Post
You get +3dB for double the power and + 3dB for double the swept area. Hence +6dB for two subs.
Source: SB Duet, Pre/Pro: Integra DHC-9.9, Speakers: SGR MT3FSL (active), Sub Amp: Crown K2, Subs: 2x SGR Maelstrom-X (125L Sealed)
Drizt is offline
post #75 of 79 Old 12-29-11, 09:21 AM
Bubba
Okay, thanks!
black_z is offline
post #76 of 79 Old 12-30-11, 07:03 PM Thread Starter
Graham
I have not done much other than listen to the subs, I have been very busy at work, I have worked every day since mid September. I hope to touch base with you mid Feb and maybe do some graphs.
Gregg
GPHammer is offline
post #77 of 79 Old 12-31-11, 12:54 AM
gperkins
Wicked Gregg. Are they still giving you a big smile on your face.
post #78 of 79 Old 01-03-12, 01:11 AM
I look at those and think of the 80's?memorex commercial where the guy is sitting in front of the speakers and holding on to the chair.And just a thought for anyone building a large cabinet,measure the doors you have to bring them thru.a 32" cab won't go though a 30" doorway!
daddywoofdawg is offline
post #79 of 79 Old 12-06-18, 05:46 PM
New Member
Hi on the behringer ep4000 what did you set your switch to on the back for sub duty as i have one but just cant figure out how they go weather they go to the left or right and and whitch one goes left and which ones go right. Any would be appreciated
Alanball10 is offline
100 , 15hz , build , cu , ft , ht , ixl
