sonosub planning phase - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 47 Old 11-10-11, 09:50 AM
Mike P.'s Avatar
Mike
Re: sonosub planning phase
Going back to post #37. Port length should be 19.8 inches , not 27.82". All three models are going to need a hi-pass filter, the 24.25 hz and the 19.8 hz tuning to protect the driver, and the 14 hz tuning because the airspeed would be too high without one.
We're all in this together!
Mike P. is offline
post #42 of 47 Old 11-10-11, 09:56 AM Thread Starter
Randy
Send a message via AIM to yourgrandma
I thinkbthe longer port length was to accomodate an 8" port diameter. I dont have access to win isd but i think that was how it broke down. I *should* be able to fit three 8" ports I think.
What are your thoughts on the volume changes involved in the inactive ports? Should I add that volume to the models of the lower two tunes to be more accurate?
Thanks for checking my work, I tend to miss some important details...
Onkyo 805 | Definitive Technology ProTower 400s | ProCenterC2 | BP2x | ProMonitor 100s | Dayton RF 12 HO slot ported thingy | Optoma HD70 | Play Station 3 |
yourgrandma is offline
post #43 of 47 Old 11-10-11, 10:30 AM
Mike P.'s Avatar
Mike
8" ports would be about 27.5" long each. The unused ports add to the net volume of the box, each one is .8 cu.ft. Here's how they model with 1000 watts and the appropriate hi-pass filters for the two higher tunings.
Mike P. is offline
post #44 of 47 Old 11-10-11, 11:13 AM Thread Starter
Randy
Thanks a bunch, Mike. They seem to roll off a little more steeply than id hoped, but thats the HPF, in your opinion is there anything to gain by lengthening the ports a bit more to get the low tune right at 14hz? Also, would you say 8" is adequite with some big flares? Or do i need to figure something else out? I was thinking of either square or even rounde triangular mdf ports. So long as the area is the same the shape doesnt matter much, right?
post #45 of 47 Old 11-10-11, 01:23 PM
Mike P.'s Avatar
Mike
A 15 hz tuning would be as low as I'd go, just my opinion. 8" diameter ports with flares will do the job just fine. Round would be better as it's said they flow air better.
Mike P. is offline
post #46 of 47 Old 11-10-11, 01:32 PM Thread Starter
Randy
Is there any rule on how far apart the ports sould be? Im thinking of trying to fit them all behind an 18" speaker grille. Either that or im sure ill have enough scrap to make an mdf ring and slap some fabric over it.
post #47 of 47 Old 11-10-11, 01:46 PM
Mike P.'s Avatar
Mike
They can be close together, just make sure there is enough material in between them for a secure mounting.
Mike P. is offline
phase , planning , sonosub
