Monkey see, monkey do... two RL-P18s for me too! - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 151 Old 10-14-07, 08:39 PM Thread Starter
Bradley
Re: Monkey see, monkey do... two RL-P18s for me too!
brucek wrote: View Post
If you read a few pages of starting from here...
OK, I see it now. I apologize for being in a hurry and not looking more carefully at all 8 pages of that PDF document. Apparently I had a major brain fart. It certainly does couple the driver to the box via the magnet brace.
Interesting concept. I don't think that it would be trivial to implement, though, because you'd have to be pretty much "spot on" (as the British say) with the dimensions to ensure a snug fit into the magnet.
Progress report: all 24 panels (to make both boxes) have been cut! Time to fire up the router.
Bradley
P.S. If this box design turns out to be a flop, I can always order up some 24" or 30" sonotube.
Bradley is offline
post #62 of 151 Old 10-14-07, 09:20 PM
Will
Send a message via AIM to WillyD Send a message via Skype™ to WillyD
The vent on the back of the driver should ideally have clearance equal to its diameter as well
Do you know the diameter of the pole vent on the Rl-p? I can't find that spec anywhere. I know TC just recommended a min of .8" clearance for the TC-2000.
WillyD is offline
post #63 of 151 Old 10-14-07, 09:21 PM
Will
P.S. If this box design turns out to be a flop, I can alway order up some 24" or 30" sonotube.
Boy, that would be a lot easier.
WillyD is offline
post #64 of 151 Old 10-14-07, 10:24 PM Thread Starter
Bradley
WillyD wrote: View Post
The magnet vent hole is flared so that makes it harder to measure. Earlier today I just grabbed a tape measure to get a quick approximate measurement. Seemed like about an inch and a half. But I will see if I can get my caliper in there and produce a more accurate number.
Edit: it's no more than 1.375 inches. I stuck the jaws of the dial caliper in as far as I could while keeping it square with the back of the driver and the hole. I think I got close to the "bottom" of the flare, so that number probably isn't too far off.
Bradley is offline
post #65 of 151 Old 10-15-07, 12:30 AM Thread Starter
Bradley
Bradley wrote: View Post
I guess I will just compromise and move the tube back half an inch. It's not the end of the world if the port outlet is 7.5" from the rear wall instead of 8. It has ample clearance in all other directions: 11.5" to side wall, 8" to top and bottom walls, 10.625 to front wall. Also, the MDF brace doesn't look like a "wall" to the magnet vent. Moving half an inch away will put it 1 3/8" from the vent hole instead of the ideal 1 1/2 inches. That isn't too bad considering a) the brace is only 3/4" thick and will have rounded edges, and b) the port tube outer wall (a much more significant "obstacle") will sit 2 5/8 inches from the rear of the magnet.
Update:
Since the magnet vent hole seems to be 1 3/8" diameter, the center brace is now exactly one diameter from the vent hole.
Measuring precisely from the edge of the main port opening (and not even thinking about the port wall thickness) to the rear wall is 7 9/16". The port I.D. is right around 8 3/8". So the discrepency in port placement is 8.2%. I don't think I'm going to lose sleep over that.
(note: this picture diagram doesn't take into account port wall thickness of approx 1/8")
Bradley is offline
post #66 of 151 Old 10-15-07, 04:59 PM
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
I don't think that running a clipped signal of 500-600 W will/can do any harm to the RL-P18, It will sound very vey bad though!... And I would never be afraid of bottoming out an RL-P18 (80 mm P-P) with such power even tuned at 16 Hz....(I'm using 2KW amp/driver...) Trust me
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Blaser is offline
post #67 of 151 Old 10-15-07, 08:05 PM
SteveCallas's Avatar
Steve
I salute your effort to get it done right
SteveCallas is offline
post #68 of 151 Old 10-15-07, 08:47 PM Thread Starter
Bradley
Well, it's no sonotube... but I tried!
Bradley is offline
post #69 of 151 Old 10-16-07, 04:32 PM Thread Starter
Bradley
Cut my first circle last night!
What a mess...
If I don't die from MDF dust poisoning, these subs are gonna rock.
Bradley is offline
post #70 of 151 Old 10-16-07, 04:37 PM
Scott
Ah, that dust should read: "Bradley was here." or "Big bass ahead."
Scott S is offline
monkey , rlp18s
