Stereo Integrity HT 18" Alfa-74 project - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 107 Old 09-28-13, 01:02 AM
vann_d's Avatar
vann_d
Re: Stereo Integrity HT 18" Alfa-74 project
vann_d wrote: View Post
The sketch does not look accurate because the 700mm triangle sides and the 750mm enclosure height look so disproportionate. In fact, if your enclosure was a right triangle with 700mm sides, the baffle width would be around 980mm. Wider than your enclosure is tall! I suggest you double check your measurements in your sketch.
Nevermind, upon closer inspection it looks like your enclosure height is 1750mm. That makes a lot more sense. Carry on. Good luck with the port configuration....
vann_d is offline
post #12 of 107 Old 09-28-13, 10:12 AM Thread Starter
You are right, as matter of fact i just increase the height to 1800mm or 180 cm.
Also you are right with the ports.I'm having some issues with the design but i finally have two options. I will post them later today.
alfa-74 is offline
post #13 of 107 Old 09-28-13, 02:57 PM Thread Starter
Well, this project is a little slow because I have limited time, but its moving forward.
As I said before, now I have 2 options with more details, but I have some doubts and I would like get some feedback.
Option 1
I'm targeting for a total internal volume of 543L (19.17 ft3) so after deducting driver, ports,braces, I still get 500L (17.65).
The plan is build the enclosure with 19mm MDF (3/4") and use a double layer for the bafle and allow flush mount of the sub-woofer, so only the baffle will have 38mm (1.5") thickness.
The shape will be triangular with 700mm each side and 1800 mm (180cm) height, these are internal dimensions.will have also 2 small sides of 100 mm.
This option will have 2 flated ports of 6" by 56cm lenght, and will use elbows in order to make it fit inside the box.
I will add also 2 braces, one of them will provide support to the ports.
Adding some sketches
The first pic is complete view of the enclosure
The second is sectional view, showing the port position and braces.
alfa-74 is offline
post #14 of 107 Old 09-28-13, 03:03 PM Thread Starter
Now Option 2
Everything is the same, size, volume, etc.
The only difference is the port. For this option I was trying to fit a slot port. But given the restriction of enclosure shape, I tried to placed in a vertical position along the baffle. But I have some concerns about the change of direction of 90 degress in order to put the discharge on front baffle.
Some sketches added
alfa-74 is offline
post #15 of 107 Old 09-28-13, 03:05 PM Thread Starter
Any advise?
What would be the best option?
I think its option 1 with flared ports.
Also, is there something else that I need to consider regarding the enclosure design?
Thanks a lot
alfa-74 is offline
post #16 of 107 Old 09-30-13, 01:37 PM
vann_d's Avatar
vann_d
I like option 1 better because I think the round ports give more predictable results than slot ports. I also like your bracing scheme better with that design. I would try to add a couple more braces with dowel rods to the middle of the bigger unsupported section.
Also, have you thought about stuffing the enclosure with fiberglass insulation or polyfill?
vann_d is offline
post #17 of 107 Old 09-30-13, 09:06 PM Thread Starter
Thanks Vann D
Yes, I think I will go with the 2 flared ports option.
Regarding braces, how many would be ok? 4?
I was planning to use this shape for the braces. Is it ok? Should I go with a different shape? for example window?
About stuffing, that was going to be my next question or questions.
Is it necessary?
How much? Where?
I was thinking about using Delcron, covering the 2 surface behind the driver, is it ok?
Regards
alfa-74 is offline
post #18 of 107 Old 09-30-13, 11:02 PM
gorb's Avatar
Nice. Most of the projects I've seen involving that driver have just been multiple sealed boxes (which are of course very nice), but it's nice to see a big ported one being done. I also like the shape you're going for, so I'm looking forward to seeing the photos throughout the build process and of course the finished product.
gorb is offline
post #19 of 107 Old 10-01-13, 02:31 AM
▀art West-VL.'s Avatar
Bart
connect the front center of the brace also with the middle of the sides
Break in your loudspeakers at 35% RMS power:
Right-click → 'save as...'
(hit "repeat")
Last edited by ▀art West-VL.; 10-01-13 at 02:36 AM. Reason: added drawing adjustment
▀art West-VL. is offline
post #20 of 107 Old 10-01-13, 08:19 AM Thread Starter
▀art West-VL. wrote: View Post
Great!!
I will do that, looks better
Thanks
alfa-74 is offline
alfa74 , project , stereo integrity ht 18
