Funk Audio TSAD18v1 Passive Radiator Build - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 23 Old 03-24-14, 05:30 PM
Gary
Re: Funk Audio TSAD18v1 Passive Radiator Build
I think they are the same.... They look so sweet
http://funkaudio.ca/product/8-3-subwoofer
Viggen is offline
post #12 of 23 Old 03-24-14, 11:51 PM Thread Starter
chrapladm wrote: View Post
Do the passive radiators have the same cones?
They do. I've attached an Image.
kawika is offline
post #13 of 23 Old 03-25-14, 02:42 AM
HTS Senior Moderator
chrapladm's Avatar
Papi
Gorgeous!!!! I might have to do some of his PR's. Although who knows with my ever changing mind of subwoofers.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #14 of 23 Old 03-25-14, 04:33 AM Thread Starter
I made a little more progress today. I've got the sides, braces, and tops and bottoms assembled. Tomorrow I attach the front and back. Then I pull the screws and prep for paint. Still haven't figured out the grills. Nathan recommended 1.25 to 1.5 inches between the front of the mounting flange and the grill. Trying to finish by Sunday. We have a walking dead season finale party at my house.
kawika is offline
post #15 of 23 Old 03-25-14, 11:09 PM Thread Starter
The box is assembled. It's heavy! I'm going to have to put it on casters. Time to start puttying the holes or pookas as we call them in Hawaii. I figured out the grills. I'm going to use a 1 inch wide by 1.5 inch tall 21.5' x 21.5'square frame. I found a shop here that sells different types of metal grill material. I'll have them cut it to a 20.5 inch square and flush mount them to the frame.
kawika is offline
post #16 of 23 Old 03-26-14, 12:55 AM
chrapladm's Avatar
Papi
Looks good. All that work looks like you need to have some pupu's after your progress.
Are you a kama`aina?
post #17 of 23 Old 03-27-14, 02:58 AM Thread Starter
Looks good. All that work looks like you need to have some pupu's after your progress. Are you a kama`aina?
Born and raised.
kawika is offline
post #18 of 23 Old 03-27-14, 06:08 AM Thread Starter
Working on the grills and prepping for paint. They're stainless steel.
kawika is offline
post #19 of 23 Old 03-27-14, 07:10 AM
chrapladm's Avatar
Papi
Will these be glued or screwed on to be held in place?
Does that material flex very much at all?
post #20 of 23 Old 03-28-14, 06:29 AM Thread Starter
I'm going to screw them and add a trim over the border to hide the screws. I was a little worried, but after screwing it down, there was very little flex. If I had to do it over again, I would use something a little thicker. Now I need something rubber to go around the edge of the metal grill. I'm looking for something like the rubber strip used on the outside of the waffle type grill. Anybody have a suggestion?
I was able to prime and put one coat on tonight. It's 1:30 am. I'm going to sleep. Tomorrow, I put the casters and input terminals on the bottom of the enclosure, finish building the grills and put on the second coat of paint. Should have her up and running by Saturday.
kawika is offline
audio , build , funk , passive , radiator , tsad18v1
