Funk Audio TSAD18v1 Passive Radiator Build - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 23 Old 03-22-14, 03:34 AM Thread Starter
I finally started the project. Originally I was looking for a high quality sub amp. This lead me to Funk Audio. Nathan and I discussed my goals for my home theater system and after many e-mails I finally settled on the system I'm currently building.
Amplifier:
Funk Audio 2.4kw x 2 version 1. This is the same amp module used in the 18.0 subwoofer. Just add another module and place it in it's own chassis.
Speakers:
Two Funk Audio TSAD18v1 18 inch drivers
Passive Radiators:
Four Funk Audio PHSAD18v1 passive radiators
Enclosure Details:
Each driver will have a net internal volume of 220L
I'll post more pics tomorrow and give a little more detail regarding the enclosure design.
kawika is offline
post #2 of 23 Old 03-22-14, 04:17 AM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: Funk Audio TSAD18v1 Passive Radiator Build
Those are great subwoofers Nick has. Any pics of the amp? And do you have a retail price on the amp? Is there any DSP also?
Nick has always had some of the best finishes on subwoofers I have ever seen. So seeing you are building using his products I have a lot of questions.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #3 of 23 Old 03-23-14, 09:28 PM
Gary
Looks like he did include a pic of the amp and like he stated its in its own chassis
Also love more info on the cost of what you purchased from him.
I see the amp does have a menu button and a few other buttons that I cannot read
Viggen is offline
post #4 of 23 Old 03-23-14, 09:45 PM
chrapladm's Avatar
Papi
My mistake on the amp picture. It was just hard to see in the pic was all.
post #5 of 23 Old 03-23-14, 11:21 PM
kawika wrote: View Post
Amplifier:
Speakers:
Passive Radiators:
Enclosure Details:
Awesome build! How much did the subs cost if you don't mind?
ClevelandFreeman is offline
post #6 of 23 Old 03-24-14, 03:43 AM Thread Starter
chrapladm wrote: View Post
Viggen wrote: View Post
ClevelandFreeman wrote: View Post
Let's put it this way. The build is going to cost me about 60% of what it would cost to purchase two 18.3 subwoofers.
I'll post some better pictures of the amp soon.
kawika is offline
post #7 of 23 Old 03-24-14, 03:54 AM Thread Starter
I've made a little more progress. I've finished glueing and screwing the two panels of each of the sides, front and back together. I wanted to flush mount the drivers, so I used a router and a circle jig to cut out the respective holes and glued the two 3/4 inch pieces together. Instead of using clamps, I used 1"1/4" wood screws. After assembly, I'll remove the screws and fill the holes with wood putty.
kawika is offline
post #8 of 23 Old 03-24-14, 04:28 AM
chrapladm's Avatar
Papi
Are you just flush mounting the frame and adding a grille later or just leave the woofers exposed?
I know for me I added enough baffles to have the drivers surround flush so I was only curious.
post #9 of 23 Old 03-24-14, 02:49 PM Thread Starter
I'm just flush mounting the frame and adding grills later. The piece that you're looking at is the front or rear. Four passive radiators are going to be mounted directly apposed on the front and the back. The box will lay flat on the ground. The two ends will then house the active drivers, again directly apposed. The grills will have to be strong being that they are so low.
I haven't quite figured out how I'm going to make the grills. They are beautiful speakers, so I'd hate to cover them. I was thinking of some kind of metal mesh. Like something you would find on a old PE locker
Any suggestions?
kawika is offline
post #10 of 23 Old 03-24-14, 04:18 PM
chrapladm's Avatar
Papi
Do the passive radiators have the same cones?
audio , build , funk , passive , radiator , tsad18v1
