Mach 5 Audio IXL-18.4 Build - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 87 Old 11-02-09, 08:36 AM
Raven
Re: Mach 5 Audio IXL-18.4 Build
Mike P. wrote: View Post
I'm long overdue for a lot of stuff. Room treatments, REW, etc. Bills and a lack of time are my biggest problems. I'll get there eventually!
True that my friend, true that.
Lonely Raven is offline
post #72 of 87 Old 03-15-10, 10:12 PM
Jezza56's Avatar
Jezza
Hi Mike, just wondering how u are finding your Subs, i have the same drivers and a Behr 2500 amp and would like to build your design, in hindesight is there anything u would do different? I am New to this site and live in Adelaide australia, would appreciate any advice u can give, BTW your subs look Fantastic I bet they sound even better.
Regards Jezza
Jezza56 is offline
post #73 of 87 Old 03-16-10, 04:40 AM Thread Starter
Mike P.'s Avatar
Mike
Hi Jezza and welcome!
I love them, they take a beating constantly and keep on going. The only thing I would do differently is not use the egg crate foam as it has been said it has no effect. Live and learn. The EP2500 doesn't have a hi-pass filter, you may have to add one if you push the subs hard and they bottom out.
How big of a room will the subs be in?
We're all in this together!
Mike P. is offline
post #74 of 87 Old 03-16-10, 04:56 AM
gperkins
Mike,
That's what I have in mine but I wouldn't know how different they would sound. Are you using anything different?
cheers
Graham
gperkins_1973 is offline
post #75 of 87 Old 03-16-10, 05:32 AM Thread Starter
Mike P.'s Avatar
Mike
If you're referring to amplifiers, I use a plate amp for each sub that has a hi-pass filter at 15 hz.
Mike P. is offline
post #76 of 87 Old 03-17-10, 05:35 AM
Jezza56's Avatar
Jezza
Hi Mike,
thankyou for the headsup on the subs. I have ordered the MDF and will start my build next week when it arrives...very anxious..could u please post the port length u used as I want to order the Precision Ports also. I will look into high pass filter also.
Regards Jezza
Jezza56 is offline
post #77 of 87 Old 03-17-10, 01:59 PM Thread Starter
Mike P.'s Avatar
Mike
The ports are 30" long each. Start a build thread once you get started.
Mike P. is offline
post #78 of 87 Old 03-21-10, 06:09 PM
roadroach357's Avatar
roach
Hey Mike,
What plate amp are you using? I didn't see it listed in the thread unless I missed it...
roadroach357 is offline
post #79 of 87 Old 03-21-10, 06:27 PM Thread Starter
Mike P.'s Avatar
Mike
I'm using these:
http://creativesound.ca/details.php?model=SUB250R
Mike P. is offline
post #80 of 87 Old 03-24-10, 08:48 AM
Jezza56's Avatar
Jezza
Hi Mike, just wondering if you could run your eye over my boxnotes report to see if it is all OK
Regards Jezza from downunder
Boxnotes report for project: 331 litre 15.bxn
Finished size 965 mm wide 762 mm high 584 mm deep - Panel thickness 18 mm - Single Front Panel
Internal Volume: 369.6 litres Working Vol 337.3 litres Tune 16hz
Component volumes: Ports = 21.3 litres Bracing = 4.4 litres Driver = 6.5 litres Total = 32.2 litres
Cutting List
Panel dimensions show finished size
Top panel 965 mm wide 566 mm deep
Front outer panel 965 mm wide 762 mm high
Front inner panel 929 mm wide 726 mm high
Left side panel 566 mm deep 744 mm high
Right side panel 566 mm deep 744 mm high
Rear panel 929 mm wide 726 mm high
Bottom panel 929 mm wide 566 mm deep
Shelf brace 939 mm wide 558 mm deep
Shelf brace includes 5 mm all round for rebating into 4 adjacent panels
Resonances
(1) Port Resonance 220 hz
(2) Driver to bottom wall resonance 370 hz
(3) Box top to bottom resonance 236 hz
(4) Driver to top wall resonance 656 hz
(5) Driver to rear wall resonance 334 hz
(6) Box front to back resonance 313 hz
(7) Driver to side wall-1 resonance 362 hz
(8) Box side to side resonance 185 hz
(9) Driver to side wall-2 resonance 378 hz
Port details
Number of ports: 3
Internal Diameter: 103 mm
Length: 780 mm
Wall Thickness: 3 mm
Driver details
Driver size: 18 inch
Number of Drivers: 1
Location of acoustic centre
Box front to mid-depth of cone: 52 mm
Box top to driver centre: 280 mm
Offset from vertical centreline: 10 mm
Report generated at: 00:13:31 on 03-25-2010 from Boxnotes Version:3.1
Jezza56 is offline
audio , build , ixl184 , mach
