-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Need help with DIY sub build (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/175292-need-help-diy-sub-build.html)
overlord1330 05-05-19 04:01 AM
Got a Dayton ultimax um 1822 need help with box design
aceinc 05-05-19 10:16 PM
Re: Need help with DIY sub build
Tough driver to design around...
What are your criteria?
upking 05-08-19 07:46 PM
I'd go with the recommended boxes, there's not much to fiddle around outside the recommended designs.
Sealed (home theater/music): 4 cubic ft. (net internal, not including driver) for an f3 of 31 Hz, f10 of 18 Hz with a Qtc of 0.72
Sealed (music): 7 cubic ft. (net internal, not including driver) for an f3 of 31 Hz, f10 of 15.8 Hz with a Qtc of 0.62
Vented (home theater): 8 cubic ft. (net internal, not including driver or vent) tuned to 20 Hz, with 3 flared vents 4" diameter by 28.5" long, for an f3 of 18 Hz
Vented (infra-sub): 12 cubic ft. (net internal, not including driver or vent) tuned to 15.5 Hz, with 3 flared vents 4" diameter by 32" long, for an f3 of 15 Hz
If you got enough power you could also use a linkwitz transform to make the low end response better in a sealed alignment.
upking 05-08-19 09:04 PM
I tried answering your PM but it seems you can't receive PM
overlord1330 - Wed, 08 May 2019 20:50:27 -0400 wrote:
Sorry what is a linkwhits transformer
Get a cup of coffee and enjoy the following link
http://sound.whsites.net/project71.htm
In sum, it's an active filter that can correct the rolloff of a sealed cabinet, based on the box FS and QTC, with it it's possible to change the box QTC and FS, to some extend.
But to extend the low end it takes a lot of power, that can escalate quickly.
Some DSPs are capable of applying that filter. the most notable that I know of is:
https://www.minidsp.com/applications...witz-transform
You can also do that with a software if you use a pc as source for the audio.
https://sourceforge.net/projects/equalizerapo/
arsyz125 05-09-19 12:46 PM
Could build a marty box that's what 95% of people do with them. Full Marty's are huge but will give you some great lows and shake the house down. Look up marty box blueprints theirs a few different sizes.https://uploads.tapatalk-cdn.com/201...41ff89b730.jpg
Sent from my SM-N950U using Tapatalk
aceinc 05-09-19 02:34 PM
Overlord1330, first this is a forum, it is best if you don't use the PM for anything except things that are truly private. Sharing questions and answers makes it so others can gain wisdom from the collective knowledge of the forum.
Your PM to me was;
I got a crown xls 1502 to power it and box design no problem any size will work I want it ported. I know that somthing tuned to mabey 18hz
I haven't modeled UpKing's recommendations, I will later. When I used WinISD to define optimal box size for a ported enclosure the size was pretty big (21 cu. ft.). Which is why I said what I did about it being tough to design for. One thing that will help any sub system is a DSP. The crown xls 1502 has a DSP built in which will allow you to tweak the parameters to compensate for suboptimal box & room conditions. You could either drive one voice coil per channel or bridge the amp and connect the two voice coils in the driver in series (4 ohms). The results should be similar.
You haven't defined what the purpose of the sub is. Some choices could be;
Home Theater
Classical Orchestra
Classic Rock
Heavy Metal
Hip Hop
Dub Step
Reggae
Nor have you specified the size of the area, small room, large room, concert hall, open field?
As UpKing implied, different uses dictate different designs.
Fill in the blanks and more people may step in with their experience and suggestions.
overlord1330 05-09-19 02:41 PM
Sorry guys I am rusty here. I have a mini dsp to run the sub I think a 12cuft box slot port will be good I have a knock down box from pe but missing some lowes
overlord1330 05-09-19 02:42 PM
80% ht and 20% music room is 14 x20 crown xls 1502 running lowes the explosions.
aceinc 05-09-19 07:52 PM
I assume you are running the 4 Cu Ft sealed PE box. As UpKing noted you will only get an F3 of about 30Hz, not great (without help) for HT.
A 14' x 20' room assuming 8'-9' ceilings certainly should be able to be energized by this woofer. If you are using the Crown amp in bridged mode and the woofer in series mode you should be getting a maximum of ~1,550 watts. In the sealed box you have you will need to apply a boost of about 10 DB at 22Hz to flatten the curve enough get decent HT wooferage. Your DSP should allow you to make this adjustment, I would think. Although I am more familiar with a parametric equalizer.
One thing that most women will tell you is that placement is as important as size. Have you done a woofer crawl?
Here is a simplistic explanation, but I would recommend some form of DB meter (you can download an app for your phone) and a subwoofer pink noise generator.
https://lifehacker.com/use-the-subwo...er-set-5751818
overlord1330 05-09-19 08:10 PM
Your help with the. Peq adjustment was awsome. That 10 db was almost perfect until payday in 3 weeks I am buying another um18 and a behringer nu6000 or another crown 1502 what do you guys think
