-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Sonotube sub build x2 18hz (Peerless) (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/35837-sonotube-sub-build-x2-18hz-peerless.html)
BuddahX 11-26-10 05:25 PM
Re: Sonotube sub build x2 18hz (Peerless)
these didn't have a film. They been sitting in the rafters at my work for a while. There's four left. Unless when the got that job that needed these they pulled off the film off of all of them I'm not too sure. or its still on it. I thoroughly cleaned the dust off with a 120 PSI air compressor and a brush and rag. Didn't notice a film of any kind. you got me all worried now lol.
BuddahX 11-26-10 05:32 PM
Think that's the film?? I didn't know they had a film. all the sonotube builds I watched I never herd about the film. if its in there think it will compromise anything?
http://i870.photobucket.com/albums/a...s/SDC11613.jpg
http://i870.photobucket.com/albums/a...s/SDC11612.jpg
http://i870.photobucket.com/albums/a...s/SDC11610.jpg
http://i870.photobucket.com/albums/a...s/SDC11611.jpg
Mike P. 11-27-10 03:41 AM
It's hard to say by looking at the pics. Try and get under it with a sharp knife point, you'll know it's the release film if you can peel it off. The problem with the release film is most glues won't stick to it.
BuddahX 11-28-10 01:54 PM
Its not wanting to come off and the glue bond is good on the brace so Looks like im in luck. :) Went to my buddy's house used is router for top and bottom plates. wanted a good circle with a rounded edge. Parts come in tuesday... yay.
http://i870.photobucket.com/albums/a...s/SDC11617.jpg
http://i870.photobucket.com/albums/a...s/SDC11614.jpg
http://i870.photobucket.com/albums/a...s/SDC11616.jpg
BuddahX 12-01-10 08:55 PM
Dry fit the ports. Going to flush mount them.
http://i870.photobucket.com/albums/a...s/SDC11625.jpg
http://i870.photobucket.com/albums/a...s/SDC11626.jpg
Flared port just pass the center support.
http://i870.photobucket.com/albums/a...s/SDC11627.jpg
24 aluminum spacers I cut today for the top and bottom plates. Going to Polish them this weekend.
http://i870.photobucket.com/albums/a...s/SDC11628.jpg
BuddahX 12-04-10 10:47 AM
favelle 12-04-10 03:25 PM
Wow, great thread! Hope you get them up and running soon!
BuddahX 12-04-10 08:26 PM
thanx man.. Still be a few weeks waiting on a quote for some glass and need to order the metal sheet to wrap it with.
http://i870.photobucket.com/albums/a...s/SDC11649.jpg
http://i870.photobucket.com/albums/a...s/SDC11652.jpg
BuddahX 12-07-10 08:51 PM
cleaned up what will be the spacers for the top and bottom plates.
http://i870.photobucket.com/albums/a...s/SDC11703.jpg
BuddahX 12-08-10 06:29 PM
