-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Sonotube sub build x2 18hz (Peerless) (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/35837-sonotube-sub-build-x2-18hz-peerless.html)
ironglen 12-08-10 10:31 PM
Re: Sonotube sub build x2 18hz (Peerless)
Looking good: can't wait to see the unique finish you're planning. If those are hollow tubes, you might try inserting some damping material inside as mine ring from time to time and I need to do something on my big sonosub. I'm thinking of using spray-foam or caulk.
BuddahX 12-09-10 11:26 AM
Yea im going to put some acoustc foam in it. But after i paint it. Hopefully start painting this weekend.
BuddahX 12-09-10 03:53 PM
lateralj 12-09-10 05:50 PM
lookign good man, thats going to sound so sweet!
BuddahX 12-09-10 08:20 PM
Thank you. I hope so LOL. I'm pretty excited I might hook one up tomorrow just to see how it sounds. Painting will begin this weekend.
BuddahX 12-10-10 03:30 PM
well the stainless Idea is a no go.. To expensive lol. So I got a metal called Paintgrip. Its pretty much a baked on primer on a sheet of metal. Paints real nice. So I'm going to wrap the sonotube with it and will be a nice smooth finish. So the color scheme is going to be Satin black and polished Brass. Hope it turns out.
http://i870.photobucket.com/albums/a...s/SDC11721.jpg
http://i870.photobucket.com/albums/a...s/SDC11724.jpg
http://i870.photobucket.com/albums/a...s/SDC11725.jpg
BuddahX 12-10-10 07:39 PM
BuddahX 12-11-10 12:08 AM
BuddahX 12-11-10 08:19 PM
wanted more support so took out the metal pipe and put in wooden rod. the fostner bit was a bit larger than the pipe so it was a loose fit. so the wood dowels fit nice and snug.
http://i870.photobucket.com/albums/a...s/SDC11744.jpg
http://i870.photobucket.com/albums/a...s/SDC11745.jpg
BuddahX 12-12-10 09:43 PM
