-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Sonotube sub build x2 18hz (Peerless) (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/35837-sonotube-sub-build-x2-18hz-peerless.html)
chrapladm 01-23-11 09:20 PM
Re: Sonotube sub build x2 18hz (Peerless)
Did the legs that are attached to the end plate just get glued on?
I couldn't remember
BuddahX 01-24-11 04:51 PM
The legs are glued into the tube and are just screwed to the bottom plate so i can take it off. On the glass i glued it on.
