-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Sonotube sub build x2 18hz (Peerless) (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/35837-sonotube-sub-build-x2-18hz-peerless.html)
BuddahX 11-08-10 03:16 PM
This is my first attempt at building a sonotube sub. Did research and got the programs and this is what I came up with. My Original design is getting changed. Instead of a 3" port I'll be using a 4" port and the cosmetics are going to be different. I just don't want to re-draw the design lol. Here are a few pictures.
http://i870.photobucket.com/albums/a...ubeproject.jpg
http://i870.photobucket.com/albums/a...utoutsheet.jpg
http://i870.photobucket.com/albums/a...s/SDC11478.jpg
http://i870.photobucket.com/albums/a...s/SDC11479.jpg
http://i870.photobucket.com/albums/a...s/SDC11481.jpg
http://i870.photobucket.com/albums/a...s/SDC11498.jpg
http://i870.photobucket.com/albums/a...s/SDC11500.jpg
http://i870.photobucket.com/albums/a...s/SDC11501.jpg
http://i870.photobucket.com/albums/a...s/SDC11503.jpg
http://i870.photobucket.com/albums/a...s/SDC11505.jpg
http://i870.photobucket.com/albums/a...s/SDC11506.jpg
http://i870.photobucket.com/albums/a...s/SDC11507.jpg
http://i870.photobucket.com/albums/a...s/SDC11508.jpg
http://i870.photobucket.com/albums/a...s/SDC11511.jpg
bambino 11-08-10 06:31 PM
Re: 3.0 CuFt. 18hz Sonotube sub build x2
Nice progress so far, what are you gonna power them with?
I spy a ton of other drivers in the background, more speakers to come?:devil:
Mike P. 11-08-10 06:55 PM
I take it you used an elbow for the port to make the port fit, correct?
BuddahX 11-09-10 02:31 PM
I was going too but decided to stick with a 3" port. Then I wont have to worry about an elbow. I think that's enough of a port and I'm using a flared port. ordering stuff from parts express Friday. Debating in raping the tubes in a black carpet like typical builds or go out of the norm and do stainless or powder coated aluminum.
1Michael 11-09-10 06:53 PM
Re: Sonotube sub build x2 18hz (Rythmik Audio)
I would have gone with the 4":whistling:
BuddahX 11-26-10 02:01 PM
Re: Sonotube sub build x2 18hz (Peerless)
my parts are coming in Tuesday from Parts Express. I'm also waiting on a quote for two 16" dia. 1/4 thick glass for my top pieces. I will be covering the tube with metal and painting it. do something different. I'll have new pics up in a week or two.
Mike P. 11-26-10 02:30 PM
What's the model number of the Peerless subs and what are you going to power them with?
BuddahX 11-26-10 03:39 PM
Peerless 830500 12" XLS Subwoofer and two Dayton SA240-B 240W. Have one gotta order another one. I don't need a ton of power sense I can't ever turn it up.
BuddahX 11-26-10 04:26 PM
Upgraded my tool collection.. MAN I WISH I HAD A ROUTER... maybe for Christmas :). any way I screwed on the rings. just waiting for my parts to come in.
http://i870.photobucket.com/albums/a...s/SDC11609.jpg
http://i870.photobucket.com/albums/a..._6530940_n.jpg
Mike P. 11-26-10 05:21 PM
It's coming along. Did you remove the release film from the inside of the tube before you attached the end caps?
