-   Ported Subwoofer Build Projects (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/)
-   -   Klipsch driver stuffed in a Sonotube (https://www.hometheatershack.com/forums/ported-subwoofer-build-projects/38138-klipsch-driver-stuffed-sonotube.html)
yamahaSHO 01-13-11 01:14 AM
Well, I had a spare driver sitting around from a Klipsch RW-12d and I've always wanted to take a shot at a Sonosub build, so here it starts...
I don't know any real specs on the driver itself, just what the specs were for the complete RW-12d sub and know how it performed as I used to have two of them. I played around with WinISD and Sonotube.exe and came up with something that I think will do well, and if it doesn't (or I blow it), I could drop something like a TC Epic into :). I am trying to make this look as close to my PC12-NSD's as I can. I found that Parts-Express had the same top grill that SVS uses and I'll be wrapping the sub with velvet as well. As for an amp, I was looking at the Oaudio 500w amps installed in a separate box. For now, I'll see how my PE BASH 300S does with it.
I was able to find a concrete place that not only had tubes in stock, but they cut it to order. I can't say I was unhappy about that as they not only cut it to the size I wanted, but the cuts are pretty clean and square! So after picking that up yesterday, I went over to Home Depot and picked up some wood and other items. I picked up a jig today and borrowed a friend's router and went to town.
Final design.
http://carphotos.cardomain.com/ride_...4043_large.jpg
http://carphotos.cardomain.com/ride_...4044_large.jpg
http://carphotos.cardomain.com/ride_...4045_large.jpg
The end caps will be a total of 2". 2 layers of 3/4" MDF and 1 layer of 1/2 Birch plywood. I will install everything using Hurricane Nuts for easy removal of parts if I ever need to modify.
http://carphotos.cardomain.com/ride_...4046_large.jpg
http://carphotos.cardomain.com/ride_...4050_large.jpg
http://carphotos.cardomain.com/ride_...4052_large.jpg
http://carphotos.cardomain.com/ride_...4047_large.jpg
The flush mounted port is a little low, but I expect the gasket will raise it up to look more flush.
http://carphotos.cardomain.com/ride_...4048_large.jpg
http://carphotos.cardomain.com/ride_...4049_large.jpg
It's -9 out right now and was too cold in the day to cut outside, so I cut in the garage... I've had better ideas. My STi looks like it just completed a rally. :)
I do plan to line the walls with some cheap egg crate looking stuff found at Wal-Mart and probably some insulation at the top of the sub around the port. One question I had is what glue is recommended for installing the end caps? I was planning on Liquid Nails, is that a good choice?
HTNut42 01-13-11 04:16 AM
Re: Klipsch driver stuffed in a Sonotube
I've built a sonosub like this before. Using a beefy OEM polk 8 Ohm driver, and a Klipsch Sub10 amp. Mabey not a great mix of components, but in a smallish room that thing will dig deep! Surprised me actually. Anyway to your question, yes liquid nails seems to be the prefered choice of sonotubers.
It looks like you have provided your Port endcap with a lip to rest on the outer lip of the sonotube, but are you doing the same for the subwoofer endcap? I doubt the wieght of the sonotube, port, and upper endcap would be enough wieght to cause any slipping if the bottom endcap is glues well, but its a thought. Reason I ask is cause from the pics it looks like the bottom cap is just a plug that fits into the sonotube with nothing to support the tubes weight when upright. Also after you get them glued in you can run a bead of caulk around the inside edges where the endcaps meet against the tube wall. Probably overkill in this kinda project, but at least that way you know the only air leaking is coming out the port.
I've heard both ways that lining the inside of your tube with egg crate, poly fill, or others either helps, or makes no difference. The only difference it would make is by the top endcap, but it sounds like you already plan on doing that with insulation. So as far as lining the sides, I say it's fine to try it either way. I lined mine for cause I'm big on overkill. Figured it couldn't hurt.
Mike P. 01-13-11 05:32 AM
Skip the eggcrate, it's been said it has no effect. Liquid Nails or any wood glue like Elmers will work well. There should be a transparent release film on the inside of the tube, make sure you peel it off as no glue will stick to it. The tube volume is a bit big compared to the volume of the RW-12d box, go easy on the sub until you find its limits, especially with the default subsonic filter on the Bash 300 which is 17.7 hz.
yamahaSHO 01-13-11 03:56 PM
HTNut42 wrote: (Post 337796)
Liquid Nails it is!
On both end caps, the 1/2" plywood is the same diameter as the OD on the tube. I did this to not only get a flush mount in the speaker, but for strength one the ends (opposed to MDF taking a hit from a child). I think I will also finish MDF veneer with something fairly dark so when the grill is off, or you look at the driver end, it will look 'higer end'. :) For the most part, I am building this just like my SVS cylinder subs. I saw that mine have plywood on the end of their caps matching the OD of the tube.
All 3 layers of the end cap will be glued together prior to final placement into the tube. For mounting in the tube, I will use the Liquid Nails inside the tube and on the end of the tube. I also plan on caulking the inside corner. I've gotten into a habbit of that with subwoofer builds.
Mike P. wrote: (Post 337800)
I picked up some cheap egg crate stuff today, although I could find the tradional egg crate shape, so this has all kinds of weird patterns. Some say it work, others say it doesn't... It was under $10. I will pull the liner off the ID of the tube where the glue will need to contact for the end caps, although I'd imagine Liquid Nails would still stick to it.
IIRC, the volume difference between this and the RW-12d box is ~1cu/ft. Curiousity has me wondering what'll do in this box. The original one chuffed and creaked too much. I always go easy on things until I get a good feel of them. :T
08op 01-13-11 05:14 PM
i am very curious to hear how this sono works with this sub
BuddahX 01-13-11 05:55 PM
Nice work man. Wish I had a router when I did mine. I love the cones on those subs. wish I had a couple woofers from them to build something. What type of finish are you planing on doing.
yamahaSHO 01-13-11 06:30 PM
The router (and jig) really help getting things right. I do like the copper colored woofers, so hopefully the sound is what I'm looking for. As for the finish on the end caps, I was thinking something like this... Maybe darker. I would like it dark enough that it doesn't stand out under the grill, but a good enough to look at with the grill off or if someone peaks at the woofer.
http://tropicalhardwoods.com/htm/tro...s/mahogany.jpg
For the tube, I was going to have the wife do a copy of the SVS sock with the same material. The base plate and legs will probably go to eD for coating.
BuddahX 01-13-11 09:34 PM
That is going to look really nice. I love that stain color. Or a Bombay Mahogany. A nice deep dark red.
HTNut42 01-13-11 11:55 PM
yamahaSHO wrote: (Post 338042)
Yeah now that I looked at the picture better I think I can see the lip on it lol. With the lips being flush with the tube I can see how it will look like the SVS's. Keep up the good work, and keep the pics coming! :clap:
yamahaSHO 01-14-11 11:05 PM
BuddahX wrote: (Post 338223)
Thanks, I'm hoping it'll look decent. I originally wasn't planning on staining, but I just think it would look better with a nice dark finish.
HTNut42 wrote: (Post 338259)
Thanks! I'll keep posting them here. :) I probably looked at every sono build in this section of the board already.
Got a chance to do a little more work on my build today. I'm going to get the other baffle glued tomorrow and then go use a drill press to drill my holes and install Hurricane Nuts.
http://carphotos.cardomain.com/ride_...4057_large.jpg
http://carphotos.cardomain.com/ride_...4054_large.jpg
With the gasket on the port, it sits just a tad high. Screwing it down should make it flush.
http://carphotos.cardomain.com/ride_...4055_large.jpg
Couldn't find the "egg crate" stuff, but this should work. It's a bit more dense than the old egg crate stuff I have for my blow up matress which I purchased about 8 years ago.
http://carphotos.cardomain.com/ride_...4056_large.jpg
Couple of questions... I know a lot of people use about 6" of fiberglass on the port end, but I really hate that . Anyone know of an alternative that won't be so nasty and is nearly as good. I've been searching the web, but I haven't really found anything.
Also, I've seen some like to dampen the port as well. I have quite a bit of extra Dynamat from a computer build and was wondering if it would be beneficial to stick that on the OD of the port and then wrap with some more of the foam. Any thoughts?
