Crown XLS 1500 question - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 21 Old 11-19-15, 11:27 AM
ellisr63's Avatar
Ron
Re: Crown XLS 1500 question
If your volume levels exceed any level you would ever listen to, I would say save your money, and listen to it the way it is.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #12 of 21 Old 11-19-15, 02:02 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
How did you determine that the receiver only puts out 1 volt?
Regardless, if you’re able to crank it as loud as you want with room to spare I don’t see a need for the signal boosters. Remember, they also boost background noise as well. That might be a reasonable trade-off in some situations, but not yours.
post #13 of 21 Old 11-19-15, 09:51 PM
rab-byte's Avatar
Mr. Rabbit
I'm wondering how you've found that output voltage? Did you connect a multimeter to one of the terminals?
rab-byte is offline
post #14 of 21 Old 11-20-15, 07:53 AM Thread Starter
Blitz
rab-byte wrote: View Post
I called yamaha and also found it in the owners manual.
fernalfers is offline
post #15 of 21 Old 11-20-15, 08:01 AM
rab-byte's Avatar
Mr. Rabbit
Is that maybe maximum output voltage?
rab-byte is offline
post #16 of 21 Old 11-20-15, 10:06 AM Thread Starter
Blitz
yes maximum output voltage from the RCA pre-outs is 1.0 Volts
post #17 of 21 Old 11-20-15, 11:27 AM
rab-byte's Avatar
Mr. Rabbit
I would presume that the crown's input voltage of 1.4 is max w/o clipping.
So you should be fine
rab-byte is offline
post #18 of 21 Old 11-20-15, 11:38 AM
fernalfers wrote: View Post
In my experience Yamaha’s specs for output voltage can’t be relied on. The receiver I checked while composing my gain structure article was also spec’d at 1 volt, but I measured it at well over 4. The fact that you’re having no problem getting plenty of output from your Crown amp should be proof enough that their 1-volt figure is under-rated.
post #19 of 21 Old 11-21-15, 03:19 PM
This thread's turned out, not only some good info (for this specific case), but a good view into things audio.
Wayne (too.. :>)
mixsit is offline
post #20 of 21 Old 11-23-15, 08:16 AM Thread Starter
Blitz
Yes this is what i'm gathering. A few movies i watched i did crank up and it was crisp and clear but found i could not listen to it for long periods at that level because it was just to loud. Which in my case is a good thing.
1500 , crown , question , xls
