Connect all HDMI to TV and optical to Receiver? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 07-27-15, 01:39 PM Thread Starter
FargateOne's Avatar
The technical service of my cable company gave me the following suggestion. I am suspicious because I am not an expert.
To get better sound in my 5.1 HT, he suggested to connect hdmi output from the DVD-player to hdmi input to the TV and to connect the hdmi out from the set-top box (cable decoder) to the tv (see my system in my profile) and a toslink cable from the tv to the receiver. He said that the optical would carry only audio signal for a better resut. Does this make sens ?
Actually, my connections are dvd and set-top to the receiver and from the recever to tv one hdmi.
FargateOne is offline
post #2 of 8 Old 07-27-15, 02:22 PM
Kal
Re: Connect all HDMI to TV and optical to Receiver?
FargateOne wrote: View Post
It will work but one should do that only if absolutely necessary. Keep it the way you are doing it. Typically, feeding the sound through the TV will limit the format options available to the receiver. Also, there is no inherent advantage of toslink in this situation.
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is online now
post #3 of 8 Old 07-27-15, 02:32 PM
HTS Moderator
Reviewer
Mike Edwards's Avatar
what Kal said. unless you're getting artifacts in the audio or glitches I would keep it the way you have it. you it's illogical. you can test it out and A/B the results to see if it's better, but unless you're having issues that makes no sense
Mike Edwards is offline
post #4 of 8 Old 07-27-15, 03:55 PM
Lumen's Avatar
Lou
Kal Rubinson wrote: View Post
Just curious as to when it does offer an advantage?
Sent from my iPad using HTShack
I try to be as good as my dog thinks I am
Lumen is offline
post #5 of 8 Old 07-27-15, 04:31 PM Thread Starter
FargateOne's Avatar
Thank all for your quick replies.
Maybe I am a dinausore in this computor and digital sound world (atmos with...123456789 speakers set up !!!) but I supected something wrong about this advice.
...and I am a lesser dinausore since I am member of HTS.
post #6 of 8 Old 07-27-15, 08:53 PM
Kal
Lumen wrote: View Post
When you need galvanic isolation, I guess.
Kal Rubinson
post #7 of 8 Old 07-29-15, 09:41 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Can’t speak for this particular connection scheme (the one proposed by the cable company), but I’ve seen plenty of situations where HDMI to the receiver and then HDMI to the TV resulted in drop-outs in the audio with some components. Adding a toslink or S/PDIF connection eliminated the problem.
post #8 of 8 Old 07-29-15, 10:20 AM
tonyvdb's Avatar
Tony
Also note that optical will not carry the Dolby TruHD or DTS Master audio signals. So from the cable box that is ok but the Bluray player you will loose the uncompressed audio.
Home theater:
Living room system:
tonyvdb is offline
connect , hdmi , optical , receiver , tv
