ALM Family Theater automation using iRule - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
post #81 of 94 Old 01-28-14, 07:45 PM
mark
Re: ALM Family Theater automation using iRule
They sent me some codes for Ir control, They are HEX CODES and DATA codes. How do I enter them. Thanks for the help
killian is offline
post #82 of 94 Old 01-28-14, 08:06 PM
raZorTT's Avatar
raZorTT
Inside irule builder under the devices tab you should be able to right click on the "global cache codes" tree branch and select "add device code". You can then give it a name (eg power off) then enter your data code in the data field. For my soundbar the power off data code is \x02\x30\x37\x38\x37\x46\x03
then drag the action onto your UI as per normal. Sync and test it out.
raZorTT is offline
post #83 of 94 Old 01-29-14, 11:02 AM
mark
One of the data codes that I want to use is 111000100000. Do I just enter them like that? The sheet also has the Hex code and Parity. Do I need to anything with them?
killian is offline
post #84 of 94 Old 01-31-14, 06:19 AM
raZorTT's Avatar
raZorTT
I think you want the hex code.
Have a look at this tutorial from irule
http://support.iruleathome.com/custo...rticles/473957
raZorTT is offline
post #85 of 94 Old 02-17-14, 10:55 AM
Sailor_Ernie's Avatar
Ernie
PS3 IR Remote control
For anyone that wants’ to remotely control a PS3, the Schmartz PSIR-1000 has been the 'go to' device as it’s the only one that can turn the PS3 ‘on’. As far as I know there is no way to control a PS3 via IP
Unfortunately Schmartz has gone out of business. You may still be able to find a PSIR-1000 but it may not be easy.
I was able to pick one up at a Canada Computers store in Waterloo ON.
Canada Computers have them listed on their web site but it’s ‘in store only’. http://www.canadacomputers.com
They are listed as ‘out of stock’ at Amazon.com
The documentation, the utility you need, and the Pronto Codes are still available on the Schmartz web site. If you find one and you can’t locate the files, shoot me an email. I have them all.
Note that if you already have a BD Playstation controller, it's 'one or the other'. As soon as you 'link' the PSIR, the Sony unit is AWOL.
Cheers, Ernie
Sailor_Ernie is offline
post #86 of 94 Old 06-23-14, 10:59 PM
ellisr63's Avatar
Ron
I just downloaded the trial version and it doesn't like my username or password. Hopefully tomorrow I can get that figured out. How hard is it to control via serial and ip devices, Denon 4520, ISY994i, Panason ic AE8000, and software like XBMS, JRiver?
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #87 of 94 Old 09-19-14, 03:24 PM
New Member
Reading through this thread and watching it! I really like iRule so far from what I have been reading.
OP,
Any updates on your progress? Any issues you have over the past few months?
rhett7660 is offline
post #88 of 94 Old 10-28-14, 11:26 AM
Mario
I apologize ahead of time if this is the inappropriate thread for this, but, I've been using iRule (Android) for a while now, and I enjoy going in and tweaking the settings or trying to figure out the different protocols for devices.
However, from a hardware standpoint, I'm getting reeeaaal tired of waiting for my handset to re-connect to my devices (gateways) every time the handset "sleeps." I'm using the Nextbook 10SE as my handset, and am running the usual type devices (Sharp LED tv, Pioneer SC-37 receiver, DirecTV, Oppo 103, PS3). I know one of the recent iterations of iRule for Android (I think 2.0.5) was supposed to address this issue, but I haven't had any success with it. My handset is currently running version 4.0.2. Unfortunately, I haven't received much help from the iRule folks/forums on it either.
Has anyone had similar experiences and maybe found a "fix" for it? It could be my handset, router, settings, or a whole slew of other items I have totally missed, so any suggestions are appreciated. At any rate, thanks for any replies. --Mario
HT2013 is offline
post #89 of 94 Old 10-31-14, 10:56 AM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
ellisr63 wrote: View Post
Waaay behind here Ron - it is actually pretty standard stuff for irule. I currently control a Denon 4520, Panasonic 7000, OPPO 93, Lutron Grafik Eye, and my directv box. I just recently finished my music server using JRiver and I control that using Webgizmo which I can connect with through iRule.
rhett7660 wrote: View Post
OP,
Again, apologies for the late reply. The only issue I had recently was my GC-100 tanking on me - I had it replaced and was back up and running in pretty short order. I finished up the music server and added the screen to control that using Webgizmo - works pretty well. I have to get zone 2 set up and working yet, but I think that should go pretty smoothly as it should be similar to the music server screen.
HT2013 wrote: View Post
Mario,
I unfortunately won't be much help there - I use an iPad for mine and don't seem to have reconnection issues at all. Sorry... :-(
Joe
ALMFamily is offline
post #90 of 94 Old 11-02-14, 12:49 PM
HTS Moderator
doug
Finally have my isy994i setup. Are you using the Mobilinc software on the iPad/iPhone or just iRule with the Mobilinc pc programming? I was thinking that I wouldn't need to buy the Mobilinc iPhone app if I'm buying iRule to be the remote software.
dougc is offline
alm , automation , family , irule , theater
