Is something wrong with my Center speaker? REW measurements included. - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 17 Old 02-20-15, 10:20 AM Thread Starter
|Tch0rT|'s Avatar
Ryan
Re: Is something wrong with my Center speaker? REW measurements included.
Is the speaker inside a cabinet or entertainment center of some type?
No, I have a shelf on top of my TV with nothing to the side or above it other than the walls and ceilings, it's maybe 3 ft from the walls and dead center between 12.5" width of the room. I've experimented with putting it in front of the TV on a little stand recently. Looks like it'll probably go back on top.
AudiocRaver wrote: View Post
With all the additional detail in mind, it does appear that the unit could be in spec and that the frequency response variations are explainable by cancellations from reflections.
Can you show me where in the data I can see that so I know what to look for? I know from the impulse response graph that when it's placed in front of the TV I can see what I'm guessing is floor bounce. Could that be the cause of the dip at 300Hz? If I'm reading it right there's some phase issues in the dips on both top of the tv and in front of it? Do you think something like Dirac, Audiolense, or Acourate would possibly be helpful for an issue like this? I can't get away with ceiling mounting an acoustic panel since I rent. I thought about measuring it outside but it was about -12 F today, maybe in warmer weather...
Thanks again.
|Tch0rT| is offline
post #12 of 17 Old 02-20-15, 01:47 PM
Wayne Myers
|Tch0rT| wrote: View Post
Thanks again.
Measuring outside can really help, when the weather allows, but even then there is the ground reflection to deal with. I have a few old blankets I bunch up and pile together to deal with it.
Your most normal looking graph in your latest .mdat file is #3, "Center 1/2015 @ 3ft." With 1/48th octave smoothing, you can see the cancellation notches most clearly. The main frequencies are at 290 Hz and 420 Hz. The formula to use is
1 / ( frequency x 2 ) = delay
So the notches at 290 and 420 correspond to the reflections at 1.2 ms and 1.7 ms on the impulse diagram, measured from the beginnings of the impulses, not the peaks. See the attached photos.
Is something wrong with my Center speaker? REW measurements included.-1.7-ms-delay-290-hz-cancellation.jpg
Is something wrong with my Center speaker? REW measurements included.-1.2-ms-delay-420-hz-cancellation.jpg
That shows best what the speaker is capable of, and that it is probably not defective. The better MLP curve is #1. With 1/3 or 1/6 octave smoothing, which is more like what we actually hear, it really doesn't look that bad. Don't know how you feel about over the TV vs under, most would probably pick under TV for most natural source direction, but over might be the better frequency response choice in your case.
Room correction software can help, but if it was me and I got the #1 curve for center channel which is primarily dialogue for most movies (yes, that is an over-generalization) I would probably live with it - unless the system needed lots of correction and I had to buy a room correction solution anyway.
Those are my thoughts from balmy Nebraska (24 degrees).
AudiocRaver is offline
post #13 of 17 Old 02-20-15, 09:51 PM Thread Starter
|Tch0rT|'s Avatar
Ryan
Thanks again Wayne. The Impulse response have always kind of confused me somewhat since people either have one like the style of your view % Fs or the dB FS and I don't know which one to use. I thought the peaks were what to look for. Thanks for the formula. I looked at the measurement 1 from the top of the TV and the dip is about 514Hz which comes in to just under 1ms so about 1ft away causing the dip if I understand correctly but that doesn't make sense to me as the only thing near the Motif in the range is the TV it's sitting on... well maybe. The Motif is curved and it's on a base that can tilt and I tilt it down towards the MLP so maybe the curve of the speaker makes the woofers go behind the TV slightly and bounce... Hmmmm.
I'm not sure which compromise on position I like better. On top of the TV the FR does look better and I think it sounds better but looks somewhat odd with a big center on my big TV (73"), it reduces the effectiveness of my bias light a tad but not too bad, and panning between center and L & R's you can definitely hear the change in height. In front of the TV the vocals sound slightly weird but it panning between the center and L & R's is precise (I rarely hear this transition in most material though) and it doesn't reduce the effectiveness of my bias light. I'll probably put it back on top of the TV and do some more experimenting.
I don't think my system needs a lot of correction but I could be wrong, I should probably make a post about it LOL. My home theater is my living room and my wife requires the common L shape with the couches and love seat (that's actually about the only WAF thing I have to deal with in this room) and I know that's throwing off some things and makes it so I can't really add panels for the reflections (the opposite side are windows ugh). The room correction is just icing on the cake or the cherry on top I suppose, at least until I can get into a dedicated room and do room treatments.
|Tch0rT| is offline
post #14 of 17 Old 02-20-15, 11:39 PM
Wayne Myers
A 1 mS delay equates to about 1 ft longer path length (1.1 ft is more precise) than the direct path length. So if the direct path from speaker to mic is 8 ft, the delayed path length will be 9.1 ft long.
The reflecting surface will also have the correct "angle of incidence" to support a reflection in that direction. We often forget that changing the angle of a surface can do all we need by diverting a reflection, and can sometimes be a lot easier than deadening.
I also keep forgetting to mention... and this could account for a lot of what you are seeing... Often reflections with 1 ms to 1.5 ms delays are from the listening chair. When we sit in the chair, we completely change its reflective nature, so for measurements I like to take it out of the equation. A thick quilt with a furry side is perfect for this if you do it right.
  • Bunch it up so it is thick and soft with as much fluffiness and air as possible.
  • Completely cover the seat, arms, and back of the chair.
  • Shape it so there is no reflective "angle of incidence" surface. This can be easier with a pillow under it, positioned like a person sitting in the chair and slumped down to a 60 degree angle.
  • This one sounds weird, but it really works great... Using a mic with 90 degree angle calibration file, hang the mic by its cable at the MLP "center of head" point, with the tip of the mic just touching the surface if the fluffed out blanket.
Sounds like overkill, but it really is not. Even plushy blankets reflect sound, you need all that thickness and air and the disruption of angle and the mic touching the blanket to completely clean up those chair reflections.
Get rid of all chair reflections and see what is left.
post #15 of 17 Old 02-21-15, 03:13 PM
Quenten
Deleting this post as I misunderstood what I read, so it does not apply. Sorry & glad you worked it out!
Tonto is offline
post #16 of 17 Old 02-21-15, 04:11 PM Thread Starter
|Tch0rT|'s Avatar
Ryan
Ah that's where I went wrong, I didn't add in the delayed path so I was looking in the wrong areas. Doh!
Ya know my initial thought was it that it was reflections from my leather love seat but when I did the math wrong I focused on ceiling reflections then floor reflections and forgot about it possibly being my loveseat. Then I moved to another position before doing more measurements from the initial location. I put the Motif back on top of the TV and I did a few more measurements, some with blankets but they didn't make much of a difference but anyway here's proof it's fine and it's just the loveseat ugh:
mdat:
https://www.dropbox.com/s/4nuxmh5egn...2015.mdat?dl=0
Thanks again for bearing with me on this. I should've figured it out on my own if I would've just measured more.
At least I know my Motif isn't defective now. BTW the miniDSP nanoAVR-HD I won from here totally makes measuring my 7.1 system with REW easy peasy due to routing feature and verifying the EQ work.
|Tch0rT| is offline
post #17 of 17 Old 02-22-15, 03:43 AM
Wayne Myers
Love that nano series.
Sorry I didn't mention chair effects earlier. I do that stuff so automatically, I almost forget the effect it can have.
center , included , measurements , rew , speaker , wrong
