NEW TO REW. Just got a Turtle Beach Audio Advantage. I need help hooking up. - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 12 Old 06-07-08, 06:27 PM Thread Starter
HionHiFi
Send a message via AIM to HionHiFi Send a message via Yahoo to HionHiFi Send a message via Skype™ to HionHiFi
Re: NEW TO REW. Just got a Turtle Beach Audio Advantage. I need help hooking up.
brucek wrote: View Post
No, unless you have a separate amp for the mains, there's no way other than remove the cables from either the speaker or the receiver.
Usually the sub and mains levels are close already from setting up the level with the receiver test tones before you begin measuring.
You mean, when the receiver is itself is setup? If so, because I just remembered that I have yet to re-calibrate the receiver after a power outage some time back. So this may be the reason the mains, and sub are out of wack.
Could I remedy the situation, by calibrating the receiver using Audyessy. Then do a check levels, then run measurements? That should give me main, and subwoofer parity.
Whenever you alter levels you simply have to set up the Check Levels again. It won't have any effect on the soundcard calibration file or the meter file, but you need to run the Check Levels routine again... only takes a second.
No problem there.
HionHiFi is offline
post #12 of 12 Old 06-08-08, 02:28 PM
Yeah, running the auto EQ first seems to be the way to go if you have a BFD and Audyessy. After you have run the auto eq, run REW and see how it looks. Then add any BFD filters and remeasure.
brucek is offline
advantage , audio , beach , hooking , rew , turtle
