REW with USB 7.1 external sound card - not working - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 22 Old 01-22-17, 07:02 AM
Re: REW with USB 7.1 external sound card - not working
Hi Tim,
REW should not have any problem addressing the IO's ( through ASIO4ALL ) of any generic 2-chnl USB soundcard ( especially at 44.1/48K sampling rates ) .
Since you are experiencing just the opposite ( consistent multiple failures on all your generic USB devices ) I'd suggest that REW/JAVA is hung-up somehow.
In REW's drop-down menu called "Preferences" choose "Delete preferences and shutdown" > this action will clear-out the cob-webs and allow REW to start anew ( this has worked wonders in the past for others with funky, inexplicable gremilins ) .
If that's not helpful then check your JAVA settings and update to the latest flavor available ( I just did and its stable with REW ).
Failing success here ( after a JAVA update ), download the REW version that bundles JAVA with it ( this has apparently worked wonders for the stability of running REW in the Mac world ).
EarlK is offline
post #22 of 22 Old 01-24-17, 05:17 AM
Hi Earl, the Java driver works fine with REW for the USB soundcards.
I did do the delete preference, and Java update just to reset those aspects, but still get the same response - fine with Java driver, but same previously described response when attempting to use the ASIO4all driver. I'm doubting that reinstalling REW with the REW + Java package is going to change operation, so I'll leave that for now. Ta, Tim
trobbins is offline
71 , card , external , rew , rew usb , sound , usb , working
