cal file, mistakenly used USB cal file in sound card setting. - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 08-11-15, 01:05 PM Thread Starter
New Member
Always learning
Sirs
I'm using REW to understand reverberation time in our church sanctuary and another large room. Not trying to EQ the system.
I mistakenly placed the UMIK-1 USB calibration file in the sound card calibration file option box before measuring 12 sweeps. A warning came up to let me know I was using the same Mic cal.txt with the sound card cal which can not be. I continued thinking I had removed the USB.txt from the sound card box, but when I looked at the data labels the same .txt file was in both.
I have now remove the USB mic .txt file out of the sound card option. Help file appears to state that if it is removed, all generated graphs (ie waterfall) would have to be regenerated, meaning my data is still good.
Question:
1. Is my data still OK now that I removed the USB cal.txt file from the sound card reference?
2. When is a sound card calibration file used in the program. During the data recording or the post processing?
3. Does the UMIK-1 USB mic have its own sound card the OS uses? The documents always state the sound card cal is not needed with a USB mic.
Thank you, John
PS: Outstanding software and thank you for all the help documentation.
customerloyalty is offline
post #2 of 3 Old 08-11-15, 02:42 PM
REW Author
JohnM's Avatar
John
Re: cal file, mistakenly used USB cal file in sound card setting.
The cal files are used when generating the response. You can remove the erroneous soundcard cal file from measurements you have already made by pressing the Change Cal... button on each measurement tab. When using a USB mic the output path is treated as being flat, the mic cal file corrects the input path.
JohnM is offline
post #3 of 3 Old 08-11-15, 03:21 PM Thread Starter
New Member
Always learning
Outstanding!
Thank you for the quick response, John
cal , card , file , mistakenly , setting , sound , usb
