Average the responses? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 10 Old 08-13-15, 11:14 PM Thread Starter
How does the (Average the responses) feature select the frequency where it combines the frequency response?
kc999 is offline
post #2 of 10 Old 08-15-15, 09:55 AM
REW Author
JohnM's Avatar
John
Re: Average the responses?
The responses are average at all frequencies for which they overlap. If you want to merge responses at some frequency there is a merge B to A option in the All SPL graph trace arithmetic controls, in that case the merge frequency is specified in the controls.
JohnM is offline
post #3 of 10 Old 08-15-15, 10:00 AM Thread Starter
Thank you. I've tried the merge function it leaves a dip it does not sum the merge point.
kc999 is offline
post #4 of 10 Old 08-15-15, 10:05 AM Thread Starter
Also when I apply the offset dB to raise or lower the frequency response in order for them to match and then merge the two frequencies, the merged plot still has the different dB at merge point.
kc999 is offline
post #5 of 10 Old 08-15-15, 10:33 AM
REW Author
JohnM's Avatar
John
Merge matches level and phase at the merge frequency, there is no need to do any manual offsetting. If you post the measurements you are trying to merge happy to take a look.
JohnM is offline
post #6 of 10 Old 08-15-15, 10:43 AM Thread Starter
Thank you much. not necessary just experimenting with few frequency responses i had imported from SE.
kc999 is offline
post #7 of 10 Old 08-15-15, 01:51 PM
REW Author
JohnM's Avatar
John
Did the imported responses have phase data or magnitude only? Just noticed there is a bug if merge is attempted on a pair of responses that only have magnitude data that would prevent the result measurement being generated.
JohnM is offline
post #8 of 10 Old 08-15-15, 02:02 PM Thread Starter
magnitude only. my bad it looks like there is phase. if you like i can email them to you
kc999 is offline
post #9 of 10 Old 08-15-15, 02:07 PM Thread Starter
kc999 is offline
post #10 of 10 Old 08-15-15, 02:12 PM Thread Starter
kc999 is offline
average , responses
