Quick Question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 12 Old 03-02-16, 03:49 PM Thread Starter
Quick Question
When taking measurements from the listening position, should the mic be facing straight up or at the speakers?
jcmusic is offline
post #2 of 12 Old 03-02-16, 06:28 PM
Re: Quick Question
Generally straight at the speakers depends what mic you are using and were you bought it from + calibration file
You can get calibration files 45 & 90 degrees as well, but general ones are 0 degrees.
Phillips is offline
post #3 of 12 Old 03-03-16, 08:29 AM Thread Starter
Re: Quick Question
I have the 8000 mic and the downloaded cal. file.
jcmusic is offline
post #4 of 12 Old 03-03-16, 12:36 PM
Lumen's Avatar
Lou
Re: Quick Question
Up or down is generally used for room acoustics. Close to, and aimed at a particular speaker is generally used for simulating anechoic response (speaker minus room acoustics). If you're going to use the 0-degree orientation, aim the mic between the speakers.
I try to be as good as my dog thinks I am
Lumen is offline
post #5 of 12 Old 03-03-16, 12:37 PM
Re: Quick Question
Do you have generic one?
If so straight at the speakers
If so I would not be doing any EQ of those measurement's, but just for acoustic measurement's should be fine or waterfall graphs.
Phillips is offline
post #6 of 12 Old 03-04-16, 02:31 PM
Re: Quick Question
Yes at the speakers!
systemhd is offline
post #7 of 12 Old 03-04-16, 07:46 PM Thread Starter
Re: Quick Question
Phillips wrote: View Post
Why wouldn't you use the measuements for EQing?
jcmusic is offline
post #8 of 12 Old 03-05-16, 11:43 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Quick Question
You don’t want to EQ based on a measurement from a generic calibration file, if that's what you have. You want an accurate graph for equalizing, and that requires a specific calibration file for the specific measurement mic used.
post #9 of 12 Old 03-05-16, 07:46 PM Thread Starter
Re: Quick Question
Hey Wayne,
I am using the one for the Behringer 8000 that I downloaded from this site...
jcmusic is offline
post #10 of 12 Old 03-07-16, 11:31 AM
Re: Quick Question
That’s a generic file. As you can see from the graph below, that is also posted on the page where you downloaded the file, response at the frequency extremes can vary several dB from one sample to the next.
ECM8000 Sample Response Variation
question , quick
