[REQ] Extend lower bound for band limited white noise - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 06-07-16, 04:13 AM Thread Starter
3ll3d00d's Avatar
Matt
I was attempting to generate some band limited white noise today and noticed that it can only go down to 10Hz. Is it possible to extend this? 5Hz would do, 1Hz would be great though
3ll3d00d is offline
post #2 of 8 Old 06-07-16, 02:41 PM
REW Author
JohnM's Avatar
John
Re: [REQ] Extend lower bound for band limited white noise
Sure, I'll remove the lower limit in 5.17 beta 3.
JohnM is online now
post #3 of 8 Old 06-07-16, 03:07 PM Thread Starter
3ll3d00d's Avatar
Matt
JohnM wrote: View Post
Great, thanks.
3ll3d00d is offline
post #4 of 8 Old 07-04-16, 03:23 PM Thread Starter
3ll3d00d's Avatar
Matt
FWIW you marked this as fixed in 5.17b3 but the lower bound is still stuck at 10Hz as far as I can see.
3ll3d00d is offline
post #5 of 8 Old 07-04-16, 04:22 PM
REW Author
JohnM's Avatar
John
The White PN signal is flat down to the lowest frequency of the chosen FFT length, which is below 1 Hz for 64k FFT and above (for the shortest 8k FFT the limit is just over 5 Hz at 44.1k sampling).
JohnM is online now
post #6 of 8 Old 07-04-16, 04:27 PM Thread Starter
3ll3d00d's Avatar
Matt
ah ok so unchecking the low cut box expands the lower limit as opposed to it being user selectable?
3ll3d00d is offline
post #7 of 8 Old 07-04-16, 04:52 PM
REW Author
JohnM's Avatar
John
It was changed for the full range noise. The low and high cut controls are shared between pink and white noise signals, the pink signals follow the pink profile to 9 Hz so allowing lower cut frequencies for them would be misleading. Is there a particular requirement for varying the low cut below 10 Hz for the WhitePN signal?
JohnM is online now
post #8 of 8 Old 07-08-16, 08:46 AM Thread Starter
3ll3d00d's Avatar
Matt
it's predominantly a UI issue as it's not obvious that unchecking the box results in a full range signal, it would be nice to have the option though to limit it to a particular frequency though just to have that extra flexibility in what sort of signal one can create.
3ll3d00d is offline
band , bound , extend , limited , lower , noise , req , white
