USB Mic Acoustic Timing - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 29 Old 11-09-16, 12:10 PM Thread Starter
Re: USB Mic Acoustic Timing
JohnM wrote: View Post
The biggest, but the biggest should always reach 100% or 0 dB if the impulse graph controls are set to normalise to the peak.
Thanks John
It seems to be sometimes a smaller negative peak then a larger negative peak is this normal?
I have looked back on other measurements and sometimes the biggest peak has gone from negative to positive with absolutely nothing changing other than possibly mics or postioing. Im confused why this could happen
I'm I doing something wrong?
Thanks again
Phillips is offline
post #22 of 29 Old 11-10-16, 07:57 AM
REW Author
JohnM's Avatar
John
Phillips wrote: View Post
Yes
The overall sum of signals varies with position.
Probably not.
JohnM is offline
post #23 of 29 Old 11-10-16, 12:10 PM Thread Starter
Hi John thank you
Even with small mic positioning it change from a peak to a negative?
I am trying to see if my centre is out of phase. This is a negative
Thank you
Phillips is offline
post #24 of 29 Old 11-11-16, 09:02 PM
REW Author
JohnM's Avatar
John
it is difficult to comment on without measurement files.
JohnM is offline
post #25 of 29 Old 11-14-16, 08:41 PM Thread Starter
Hi John I have checked the polarity and it is connected correctly but the graphs shows incorrect polarity.
I have swapped the wires and polarity is good now, according to the graphs
Is it common that the internal wiring has been incorrectly wired?
Sorry at the moment I cant post files
Thanks again
Phillips is offline
post #26 of 29 Old 11-23-16, 06:46 PM Thread Starter
Hi John to setup up the timing acoustic do I leave all the measurements with Acoustic Timing selected?
Thanks
Phillips is offline
post #27 of 29 Old 11-24-16, 01:55 PM
REW Author
JohnM's Avatar
John
Sorry, I don't understand the question.
JohnM is offline
post #28 of 29 Old 11-27-16, 08:48 PM Thread Starter
Hi John e.g. Left Main is reference do I measure with Acoustic Timing (in preference's) ticked for all measurements including the reference (in this case Left Main)?
Thanks
Phillips is offline
post #29 of 29 Old 11-28-16, 01:15 PM
REW Author
JohnM's Avatar
John
Yes, keep it selected for any measurement that you want to have timing for.
JohnM is offline
acoustic , mic , timing , usb
