Spl graph issue-not appearing - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 19 Old 01-09-17, 12:09 PM Thread Starter
Hi!
I'm new to rew so maybe it is a noob question but I don't find this problem anywhere in this forum...
I'm successfully doing calibration and measurement after that the graph's appearing but with only phase measurement .. nothing else even if I click on spl under the graph..
On the folder left sided I can see the graph but in thumbnail format only ... is it me or a bug?
Thanx
Liovanc is offline
post #2 of 19 Old 01-09-17, 12:30 PM Thread Starter
Re: Spl graph issue-not appearing
/Users/Lio/Desktop/Capture d’écran 2017-01-09 à 17.44.58.png
Maybe it helps understanding
Liovanc is offline
post #3 of 19 Old 01-09-17, 01:56 PM Thread Starter
No one really?
Liovanc is offline
post #4 of 19 Old 01-09-17, 01:57 PM
REW Author
JohnM's Avatar
John
I suspect a problem with your SPL calibration is resulting in your graph being off the top of the range - if you put the graph cursor within the measured range you can see what the SPL value is. If that is the case you will just need to do the SPL calibration, per the help to fix future measurements, for that one you could offset the result using the graph controls (gear icon to top right of graph) to get it back within range.
JohnM is offline
post #5 of 19 Old 01-09-17, 02:19 PM Thread Starter
Thank you,
What do you think i should put more or less as numbers in the offset box?
I have absolutely no idea what it is
Liovanc is offline
post #6 of 19 Old 01-09-17, 02:50 PM
REW Author
JohnM's Avatar
John
Put the cursor somewhere in the measurement range (at 40 Hz, for example) and read the SPL value from the graph legend. Then you will know how much is needed to get it into a sensible range, like 75 dB or so.
JohnM is offline
post #7 of 19 Old 01-11-17, 05:18 AM Thread Starter
Hi John
I didn't succeed to make it appear
Even when i'm calibrating the sound card (with only the internal loop) when i'm hitting the measurement button ,there is nothing appearing in the main frame except phase..
I tried the offset like you said but still nothing.
Any other idea?
Liovanc is offline
post #8 of 19 Old 01-11-17, 05:44 AM
REW Author
JohnM's Avatar
John
Please attach the mdat file for the measurement.
JohnM is offline
post #9 of 19 Old 01-11-17, 06:03 AM Thread Starter
Here you are
Attached Files kkk.mdat (2.74 MB)
Liovanc is offline
post #10 of 19 Old 01-11-17, 06:57 AM
Liovanc wrote: View Post
Hi John
Any other idea?
The maximum offset value is limited to +/-100db ( per entry ).
So do the offset entry 3 times ( and your trace will appear at around 55db ).
It works. I just tried it on the file you posted.
EarlK is offline
appearing , graph , issuenot , spl
