First up graphs, advice appreciated - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 22 Old 02-07-09, 09:57 AM
Re: First up graphs, advice appreciated
how close to flat can one be realistically trying to achieve.?
The dip at 200Hz is quite bad. What's the problem?
Does a single speaker measured near-field in the middle of the room enjoy a flat response? Lets be sure that the room is the culprit.
brucek is offline
post #12 of 22 Old 02-08-09, 11:52 PM Thread Starter
I am sure the speakers are fine.
dodittydada is offline
post #13 of 22 Old 02-09-09, 06:20 AM Thread Starter
hmm, Im real suss on my chart. I mean, Im trapped to the * in here. Two front corner traps are a foot thick each, the ones behind the speakers 8 inches, rear traps are 6 inches thick....they are all 6ft tall and nearly reach to the ceiling. yet I still have a massive dip at 200hz in a rectangular room nearly 20ft deep??? I didnt expect flat of course, but this dosent seem right. I guess Im especially suss seeing its a dip and not a peak. Im sitting at the 38% point towards the front, I should be out of the way of any major modes.I just dont know what to do next besides start looking at slot resonators.
post #14 of 22 Old 02-09-09, 06:40 AM
Steven
dodittydada wrote: View Post
Have you tried some trapping on the ceiling between the LP and the mains before?
thewire is offline
post #15 of 22 Old 02-09-09, 08:40 AM
HTS Moderator Emeritus
Anthony's Avatar
Anthony
What are your exact room dimensions and relative speaker placement from wall/side/ceiling?
200 Hz 1/2 wavelength is about 5.5 ft. If you have an 11' dimension in the room and the speakers are right at this point, they'd be at a null.
Is there anything in the room that could be an accidental helmholtz or panel resonator? Sliding glass door, open doorway to another room. Dozens of empty water jugs in the corner? Originally my riser was acting as a panel resonator and sucking out a lot of bass until I added more insulation and doubled up on the plywood.
but that response is odd.
Anthony is offline
post #16 of 22 Old 02-09-09, 10:26 AM
REW Author
JohnM's Avatar
John
Try measuring forwards and backwards of your current position, 38% is not gospel, it is only a reasonable starting point to begin measuring to find the actual optimum for the room. Try moving the speakers also, as far as your space can accommodate. Easiest to use the RTA and the Pink PN generator when moving around, so you get immediate feedback of the effects.
JohnM is offline
post #17 of 22 Old 02-10-09, 02:07 AM Thread Starter
Anthony wrote: View Post
hmm, how about a fridge? Got one of those centre of the back wall. Could it possibly be sucking bass? with a closed door probably not. Width of the room MAY be around 11ft, not sure. Ill go measure it.
post #18 of 22 Old 02-10-09, 03:04 AM
Jim
Have you calibrated your sound card and do you have any graphs of what the room was doing before adding any acoutic panels and bass traps.
I think another worthwild question is are we really sure that your amplifier speaker combination is not causing these dips?
JimP is offline
post #19 of 22 Old 02-10-09, 03:53 AM Thread Starter
JimP wrote: View Post
unofrtunately, no testing before treatment. What possible things amp/speaker wise could cause a dip like this? At least then I know where to start investigating. thanks.
post #20 of 22 Old 02-10-09, 07:14 AM
Jim
I'm just saying that before you make yourself crazy fixing the room, be sure that you don't have something else going on with your electronics/sub/speakers. Unfortunately, if near field testing doesn't give you a flat response curve, then dragging it all outside to test it would be about the only other way to check it. How many feet of snow do you have?
JimP is offline
advice , appreciated , graphs
