Random windows generation in REW - Home Theater Forum and Systems - HomeTheaterShack.com
 2Likes
  • 1 Post By JohnM
  • 1 Post By JohnM
post #1 of 8 Old 02-03-17, 09:17 AM Thread Starter
Hallo
When using REW on my PC, often random windows are generated when I move the mouse. See attachment. I have REW 5.18, but the problem persisted when I updated to 5.19beta.
I have windows 10 on the PC.
Any idea what the cause is, and what I could do?
Thanks for the help
turboman is offline
post #2 of 8 Old 02-03-17, 09:21 AM
Wayne Myers
Re: Random windows generation in REW
I have seen problems like that when a mouse started going bad. Something to check.
AudiocRaver is offline
post #3 of 8 Old 02-03-17, 09:31 AM Thread Starter
AudiocRaver wrote: View Post
Thanks for the reply Wayne.
The mouse is 2 months old and the problem is only in REW, and in no other programs. Any idea what it could be?
turboman is offline
post #4 of 8 Old 02-03-17, 01:37 PM
REW Author
JohnM's Avatar
John
The cause is a disagreement between Java and the graphics card driver. If updating the driver doesn't fix it you can disable Java's use of hardware acceleration as explained here.
turboman likes this.
JohnM is offline
post #5 of 8 Old 02-03-17, 02:09 PM
Wayne Myers
Thanks, John. I do vaguely remember having that problem with a beta release a few versions back, and it was fixed in the next version. I have not seen it since.
post #6 of 8 Old 02-03-17, 03:23 PM Thread Starter
JohnM wrote: View Post
hallo John,
Thanks for the help. I saw the following instruction in the previous threads:
You could also try disabling Java's use of hardware acceleration by putting
-Dsun.java2d.d3d=false
in the roomeqwizard.vmoptions file in the REW program directory.
How to do this? I open the roomeqwizard.vmoptions file with notepad, and add the line. That was OK. When saving the file, a message came that access was denied.
Note: when I had the problem with the random windows, I had the latest Nvidia driver WHQL 378.49 and a GTX970 graphics card. REW was with JRE.
turboman is offline
post #7 of 8 Old 02-04-17, 07:21 AM
REW Author
JohnM's Avatar
John
Save the modified file to desktop or "My Documents"
Move it from its location to the Program File directory
You will get a UAC prompt to confirm that you want to do that
JohnM is offline
post #8 of 8 Old 02-04-17, 08:11 AM Thread Starter
Hallo John,
Beautiful! Now it works perfectly. Thanks a lot.
I understood that the Java and the graphics acceleration of the graphics driver did not like each other in such cases, and that this command line would disable that. Actually, I did not feel much difference in graphics speed. But maybe this is because I have a fast processor (i7-6700K 6.7GHz).
Thanks again for the very helpful solution and the fast response!
turboman is offline
generation , random , rew , windows
