Mid-Hi crossover time aligning with REW ? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 03-25-17, 02:36 PM Thread Starter
red
Re: Mid-Hi crossover time aligning with REW ?
Yeah, thanks a lot John, step by step is best to me...
I had it set to 'no timing….
I'll repeat when I get to the club…
Best regards
Klaus
jtalden wrote: View Post
Klaus,
Main Steps:
> Set REW 'loopback timing'/'Acoustic timing' depending on XLR/USB mic.
> Measure MR driver and TW driver
> Select the TW measurement/impulse chart
> Open the 'controls' panel
> Select 'Estimate IR Delay' Record the delay that is offered (ms).
> Select 'Shift IR' [The TW impulse will shift that amount back to near 0 ms]
> Select the MR measurement/impulse chart. In the 'controls' panel and enter the recorded offset value used for the TW IR into the 't=0 offset(ms):' entry box and select 'Apply'
[The MR IR will shift the same amount as the TW. The relative timing will be unchanged as they were both shifted the same distance.]
REW settings for phase analysis:
> Open the 'overlay/phase' graph panel.
> Set 1/48 octave filtering for both measurements.
> Activate the 'IR Windows' popup.
  • Enter 0.00 into the 'Window Reference Time' box
  • Check 'Add Frequency Dependent Window'
  • Enter '5' into 'Width in cycles' [A greater number often works fine. Using a lower number will start to distort the trace tails.]
  • Select 'Apply Windows to All'
The phase overlay graph now displays the correct relative phase between the MR and TW and should be easily read. If it is not clear then there was an error in this process.
If you shift the MR impulse location to find the offset need for proper phase tracking then it is necessary to again enter 0.00 into the 'Window Reference Time' box and select 'Apply'. Any IR shift requires resetting the 'window reference time' to 0.00 to assure the phase relationship will be correct.
redmountain is offline
post #12 of 14 Old 03-25-17, 02:40 PM Thread Starter
red
… In the mean time…
Can I convert my 'un-timed' measurements into 'timebased / correlated' ones by setting something somewhere ?
Thanks
Klaus
post #13 of 14 Old 03-25-17, 02:58 PM
redmountain wrote: View Post
… In the mean time…
Thanks
Klaus
Not without doing a lot of time-consuming work that also includes making a 3rd measurement of Mids & Hi's playing together ( and then dumping all 3 measurements into a separate passive crossover design program and then doing some manual curve-fitting to estimate an offset.
Taking new ( correlated ) measurements is by far the simplest way forward .
EarlK is offline
post #14 of 14 Old 03-25-17, 03:13 PM Thread Starter
red
Well then thanks a lot for your help
and best regards
Klaus
aligning , crossover , midhi , rew , time
