Problem with big rooms and long reverberation (>6s) - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 10-23-17, 06:14 PM Thread Starter
Hi,
I try to measure for the first time a big room with more than 6s of reverberation. It looks like REW can't handle this but maybe I miss something ... If listen to the IR wav file, I can hear a filter cutting the diffuse field ! Also the measurement with a sweep stop before the end of the reverbaration. Is there a limitation of time in the software ?
All the best,
Olivier
Problem with big rooms and long reverberation (>6s)-capture-d-ecran-2017-10-24-00.07.44.jpg
polysonolivier is offline
post #2 of 6 Old 10-24-17, 03:25 PM
REW Author
JohnM's Avatar
John
Re: Problem with big rooms and long reverberation (>6s)
To capture impulses with very long reverberation times use a long sweep (e.g. 1M) and make sure the Analysis preference for IR truncation is set to "Keep full IR".
JohnM is offline
post #3 of 6 Old 10-24-17, 06:30 PM Thread Starter
Dear JohnM, thank you for your reply ! Unfortunately I've already tried this but I have the same problem. I will give a shot with another the version 5.18 (?). Mine was in v5.14...
post #4 of 6 Old 10-27-17, 04:05 PM Thread Starter
Ok it seems to work perfectly well with the v18 ! I still have a question about the spectrogram, it seems to be limited to 2000ms ...
post #5 of 6 Old 10-27-17, 04:09 PM Thread Starter
Problem with big rooms and long reverberation (>6s)-capture-da-cran-2017-10-27-22.04.37.jpg
post #6 of 6 Old 10-27-17, 04:13 PM
REW Author
JohnM's Avatar
John
Try the beta version, it has much wider limits.
JohnM is offline
>6s , big , long , problem , reverberation , rooms
