Room Measurments with REW Noob - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 43 Old 11-30-17, 10:28 PM
Wayne A. Pflughaupt's Avatar
Re: Room Measurments with REW Noob
Does the driver have dual voice coils? If so maybe you have the polarity off on one of them?
Also, a low pass filter might be engaged with the amp or equalizer?
post #22 of 43 Old 11-30-17, 11:10 PM Thread Starter
The_Nephilim's Avatar
Gerald
This is the original, single voice-coil 4 ohm version, Thiele-Small parameters:
Fs = 17.7 Hz
Re = 3.4 ohms[dc]
Le = 6.09 mH
Qt = 0.37
Qes = 0.39
Qms = 5.59
Mms = 434.34 grams
Rms = 8.69 kg/s
Cms = 0.184 mm/N
Vas = 274.1 liters
Sd= 1029.22 cm^2
Bl = 20.51 Tm
Lp(2.83V/1m) = 91.60 dB
Xmax = 22mm
Power Handling: 800 Watts
SPL (2.83v/1m): 89.2 db
Impedance: 4 Ohm (SVC)
Recommended Enclosure Sizes:
Sealed: 4.6 cubic feet
Ported: 7 cubic feet @ 19Hz
EBS: 12.4 cubic feet @ 15Hz
I just looked at a link that had this info and a picture of that driver he had for sale it looks just like the one I have so it is the correct driver I think..
It is a Single voice coil. I was just thinking is it possible I wired the Speakon connector wrong?
EDIT: I just checked the wire on the cabinet and the speakon connector it appears to be wired properly.. I just have to pull the driver off to make sure I have the positive and negative correct..
here is a Picture of the drive I have:
the below link is how to set the inuke to 16hz with the HPF. I think the LPF is OFF??
http://www.avsforum.com/forum/155-di...z-dcx2496.html
Thank you for helping me
The_Nephilim is offline
post #23 of 43 Old 12-01-17, 09:24 PM
Is that your sub – dual drivers?
Yes, I meant hi-pass filter, sorry. Frankly, with the capability of that sub, I don’t see a reason for a HP. I’d suggest bypassing it for the time being so we can make sure it’s not the problem.
post #24 of 43 Old 12-01-17, 09:47 PM Thread Starter
Gerald
Well when I bought it I was a Noob big time and sold the other driver OOPPPS!! Well I will get two next time out
I will remove the Filter and see what happens.. so I will take a measurement from the MLP with the Subwoofer..
I will do that tomorrow as I have some things currently going on.. I did hook the sub back up and it was definitely hooked up correctly.. I am going to install some T-Nuts on the sub tomorrow also so I can check the polarity of the wiring to the driver..
post #25 of 43 Old 12-03-17, 03:54 AM Thread Starter
Gerald
Well I did not get to check the sub earlier but I will try and get some Sunday.. IF I still get that dip with the HPF Off what would that indicate?
post #26 of 43 Old 12-03-17, 11:41 AM
Good question. Do you have another amp you can try?
post #27 of 43 Old 12-03-17, 03:10 PM Thread Starter
Gerald
No I do not.. so maybe the amp could be faulty?? I did try both channels and it did the same thing it had that dip..
post #28 of 43 Old 12-03-17, 05:14 PM
Maybe you could get an amp from a place like Guitar Center for a test, and then return it?
post #29 of 43 Old 12-03-17, 05:15 PM
Also, could it be something in your receiver? Do you have an old active sub you could try for comparison? You are using the receiver's sub output, right?
post #30 of 43 Old 12-04-17, 02:08 AM Thread Starter
Gerald
Yes I will try and see If I can rent an amp at Guitar Center or something.. Yes I am using the Subwoofer Output on my Receiver.. No I gave my old active sub to my niece..
measurments , noob , rew , room
