Applying EQ filter, get worst response: what's wrong? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 08-19-10, 11:22 AM Thread Starter
Hi,
I'm trying put EQ filter data in my DEQ2496 and see what's change in REW measure.
Seems something wrong in my operation: the result is worst then the measure with no equalize.
Original measure
Applying EQ filter, get worst response: what's wrong?-misura2-originale.jpg
Measure with EQ filter data put in DEQ2496
Applying EQ filter, get worst response: what's wrong?-misura2-equalizzata.jpg
These are data I put manually in the equaliser
Applying EQ filter, get worst response: what's wrong?-misura2-eq-filter.jpg
Where am I wrong?
Thanks,
Michele.
AcarSterminator is offline
post #2 of 5 Old 08-19-10, 12:31 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Applying EQ filter, get worst response: what's wrong?
The problem is that you’re loading filters crafted for one specific equalizer into a different equalizer. For example, here is the electronic response of a 1/3-octave-designated filter for three different equalizers.
Applying EQ filter, get worst response: what's wrong?-bfd-1124-1-3-octave-20-60-.jpg
Behringer DSP 1124
1/3-octave (20/60)
Applying EQ filter, get worst response: what's wrong?-fbq2496-1-3-octave-.333-.jpg
Behringer FBQ2496
1/3-octave (.333)
Applying EQ filter, get worst response: what's wrong?-sms-1-1-3-octave-4.3q-.jpg
Velodyne SMS-1
1/3/octave (4.3Q)
Your best bet for the DEQ would be to use REW’s RTA feature. That way you can tweak filters and see on-screen the change in response in real time.
The great majority of those filters you’re trying to use aren’t even needed. See this thread for some tips on full range equalizing (start with post #6).
post #3 of 5 Old 08-19-10, 12:42 PM
Kal
AcarSterminator wrote: View Post
Hi,
Original measure
Attachment 23179
Attachment 23180
Attachment 23181
Where am I wrong?
Thanks,
Michele.
Looks to me that you are getting the inverse of what you want. Increases where there are peaks and cuts where there are troughs. Is there something to correct that?
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is offline
post #4 of 5 Old 08-19-10, 02:27 PM
REW Author
JohnM's Avatar
John
Main problem is probably that the target level is way above the response, so first you need to use the "Set target level" control to get the level right, but first set the Speaker Type to Bass Limited with a cutoff at about 40Hz or so for a reasonable match to the response. Next problem is the equaliser type, the FBQ2496 or DCX2496 might be appropriate, but to know for sure you should make a loopback measurement through the equaliser with a filter set at (say) 1kHz, -12dB, 1/3 octave or so and see which of the REW equaliser settings (if any) gives the same filter shape as your measurement.
JohnM is offline
post #5 of 5 Old 09-19-10, 03:07 AM Thread Starter
Hi, I'm back to bring you all my apologize...
It was my fault: I put in EQ the wrong data
I didn't used "gain" colomn, but the green one on the left.
Thanks for all your interesting and useful replies.
So sorry,
Michele
applying , filter , response: , what's , worst , wrong?
