My initial readings - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 28 Old 09-03-10, 12:00 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: My initial readings
Yes, the REW Help Files includes directions on how to create a house curve file.
post #22 of 28 Old 09-04-10, 02:03 PM Thread Starter
Hi,
I've loaded a house curve with a 6 Db. raise at 20 Hz. and 0 at 80 Hz.
I've made measurements without EQ and let REW assign filters.
It's telling me to use 2 12Db. boosts on the behringer... Isn't that a bit much?. I remember that in the past people said never to boost more than 5 Db. on the behringer...
Dimitri.
Dimitri_ISF is offline
post #23 of 28 Old 09-04-10, 02:34 PM
Can you post a screen shot of the EQ panel (or at least list the filters and parameters), and your response measurement?
post #24 of 28 Old 09-04-10, 03:23 PM Thread Starter
Hi wayne.
Here they are.
Dimitri.
post #25 of 28 Old 09-04-10, 03:32 PM
Thanks. Looks like your fine. There are plenty of severe cuts to go along with the boosts. Actually, that can be just as bad a severe boosts, because severe cuts leave severe peaks between them.
Re the boost at 77 Hz: If that filter did not eliminate the depression, then you should remove it. That one looks like it might be a null.
post #26 of 28 Old 09-07-10, 01:09 PM Thread Starter
Hi,
I've added a picture of the response that I now have.
Sounds a lot better this way with way more transparent sub sound. I could use a little bit more "slam" though. It sounds very balanced, but a bit more punch would be nice. Maybe boost the lower end a bit?...
I'm also thinking about a bigger center speaker to match the Q11's. Something like the KEF bIQ6 C. Would youi guys say that's a major upgrade from the Egg?...
Thanks,
Dimitri.
post #27 of 28 Old 09-07-10, 03:06 PM
Maybe try a steeper house curve...
Yes, I think the bigger speaker would sound much better.
post #28 of 28 Old 09-08-10, 05:34 PM Thread Starter
Wayne,
I'll trie a steeper curve.
And upgrade to the KEF IQ6C.
Dimitri.
initial , readings
