REW V5 Tips - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #71 of 114 Old 08-05-14, 08:20 PM
Re: REW V5 Tips
JohnM wrote: View Post
There is no downmix feature (REW is just controlling the channel selection, not doing any processing of the signal). You can output the signal on a second channel by selecting it as the timing reference output if you are using ASIO drivers.
Thanks again, no idea what the timing reference is for as I am still new at this, but it did the trick for me to plot my all channel bass response.
SHNEE is offline
post #72 of 114 Old 08-14-14, 06:29 AM
New Member
Re: REW V5 Tips
Thank you John!!!
mEon is offline
post #73 of 114 Old 08-15-14, 01:10 AM
Re: REW V5 Tips
for chosing a specific channel to test with REW , use the new EqAPO 0.9 (search the thread) and use the new command Copy: in config.txt
ex: all my 5.1 channels are set to 0 except Rear Right which send the right channel
Copy: RL=.0 L=0. R=0. C=0. RR=L SUB=0.
xxxx5 is offline
post #74 of 114 Old 08-16-14, 06:08 AM
Re: REW V5 Tips
To save a graph that is small enough to post, is capture the only way? Using capture, I find the text font size on the axis almost twoo small to read but I cannot find a way to enlarge them.
SHNEE is offline
post #75 of 114 Old 08-16-14, 06:36 AM Thread Starter
REW Author
JohnM's Avatar
John
Re: REW V5 Tips
The graph font size can be increased in the View preferences (REW must be restarted to apply any changes to the font size). I suspect you have REW full screen and so your graph is being scaled down a lot, an alternative is to resize the REW window so the graph is closer to the size you want and doesn't need as much scaling.
JohnM is offline
post #76 of 114 Old 08-18-14, 06:46 PM
Re: REW V5 Tips
Thanks, I did try that before but didn't know it had to be restarted to take effect.
SHNEE is offline
post #77 of 114 Old 08-19-14, 06:03 PM
Re: REW V5 Tips
Hello John, are those "distortion" figures" accurate? I know they are at the mercy of the mic, sound cards, and the AVP, AVR etc., but are they other than those external factors, how accurate are the THDs shown by clicking the distortion tab? On thing I noticed was that they didn't seem consistent. Repeating "measure" would yield different THD figures, somethings consistently high, other times low.
SHNEE is offline
post #78 of 114 Old 08-19-14, 06:34 PM
New Member
Greg
Re: REW V5 Tips
thanks
Studioonthebayou is offline
post #79 of 114 Old 08-20-14, 01:41 PM Thread Starter
REW Author
JohnM's Avatar
John
Re: REW V5 Tips
SHNEE wrote: View Post
Yes
If successive measurements don't give repeatable results something is wrong with the measurement setup, which you should track down. Better starting a separate thread for that.
JohnM is offline
post #80 of 114 Old 08-20-14, 06:41 PM
Re: REW V5 Tips
Thanks John, I started a new thread, hopefully I did it right.
SHNEE is offline
tips
