REW V5 Tips - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #81 of 114 Old 09-03-14, 01:27 PM
Re: REW V5 Tips
How do I get AISO4ALL to work with REW v22???
Propoggio is offline
post #82 of 114 Old 10-23-14, 08:36 AM
Re: REW V5 Tips
Thanx J. Very handy
mollie is offline
post #83 of 114 Old 11-01-14, 02:32 PM
Steve P
Re: REW V5 Tips
thanks for the tips for rew
Steve Piazzo is offline
post #84 of 114 Old 01-12-15, 03:47 PM
Lumen's Avatar
Lou
Re: REW V5 Tips
JohnM wrote: View Post
I thought a few tips on REW V5 might be in order, I'll start with some people may not have come across. Feel free to add any tips of your own.
<SNIP>
  • Move between measurements with Alt+UP and Alt+DOWN, go directly to a specific measurement with ALT+1 or 2 or 39
  • Move between graphs with Ctrl+LEFT and Ctrl+RIGHT, go directly to a specific graph with Ctrl+1 or 2 or 39
<SNIP>
Hi John, you're REW tool is the greatest, man!!! How do you keep up?
I had some trouble getting either of the above very desirable features to work. Are they only active from a certain window or part of the screen? TIA
Lumen is offline
post #85 of 114 Old 01-12-15, 05:10 PM Thread Starter
REW Author
JohnM's Avatar
John
Re: REW V5 Tips
The shortcut keys can be a bit temperamental sometimes, they seem to get swallowed by the OS on occasion for no obvious reason, and some are used by the OS for other things - for example, on OS X the ctrl+left/right keys are used to switch workspaces so they never get to REW. They usually work though, at least on Windows and OS X with the latest REW beta (I don't have an original V5 install to try right now).
JohnM is offline
post #86 of 114 Old 02-05-15, 05:59 AM
viki_v2
Re: REW V5 Tips
Hello John
Can you kindly tell the difference between Umik-1 + Rew and Omnimic v2.
I have been through all the trouble of Having external sound card + MIc Preamp+Amplifier + MIc and had only light success.
What ever I have read till now makes the combination of Rew and Umik-1 too good to believe.
I have Omnimic in parts express Cart but have not yet purchased just bcos this reason.
viki_v2 is offline
post #87 of 114 Old 02-05-15, 02:18 PM Thread Starter
REW Author
JohnM's Avatar
John
Re: REW V5 Tips
I have no experience of Omnimic so can't really comment.
JohnM is offline
post #88 of 114 Old 02-08-15, 12:36 PM
Alpi
Re: REW V5 Tips
Hi,
REW v24 dont work with Asio4all 2.12. OS=Windows 8.1 64bit.
The System crashed and shutdown.
Any Idea?
thanks for this great Programm, Alpi
alpenpoint is offline
post #89 of 114 Old 02-08-15, 01:05 PM Thread Starter
REW Author
JohnM's Avatar
John
Re: REW V5 Tips
alpenpoint wrote: View Post
Any Idea?
Afraid not, I've just tried ASIO4All 2.12 with beta 24 and it worked OK for me on Win 8.1 64-bit, using both the 32-bit and 64-bit JREs.
JohnM is offline
post #90 of 114 Old 07-19-15, 05:11 AM
New Member
Smile Re: REW V5 Tips
thank you for the tips
marius-d is offline
tips
