?REW bug-must restart REW for input sound to register - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 03-23-11, 02:07 PM Thread Starter
Hi all
Curious if anyone has had the same problem? When I started using REW v5 for the first time and was setting up the input/output levels and calibrating my SPL meter, I found that the input from REW would show up on the input meters/SPL meters after I had initially opened the program but would not work a second time. If I then closed and re-opened REW the input meters worked again.
For example when calibrating my SPL meter, I could press on the unlit red button on the REW SPL meter to start seeing input from my outboard SPL (Radio Shack 33-4050). Once having done this though I could not calibrate as when it came time for the REW SPL to recienve input in the calibration step, nothing registered. If I then closed and re-opened the program and did not press the unlit red button on the REW SPL, I could go through the calibration steps no problem.
Anyone else seen this, any ideas??
Richard
my stuff
Mackie 1202 VLZ mixer (for outboard gear into the ...
Aardvark soundcard 24/96 (16 or 24 bit, multiple choice of Hz 44.1, 48, 96) 4 inputs -both 1/4" and XLR 6 outputs -4 of 1/4", 2 of RCA software mixer with a patch bay where internal connections can be changed (options are inputs: 2 pair, playback 3 pairs, tone, silence) overall monitor level slide
Dell, pentium 4, 266 GHz, 512 mb RAM, running WinXP sp3
N-tracks recording software
Samson Servo T120 stereo amplifier
Alesis Monitor One sudio reference monitors (flat)
richardlaroche is offline
post #2 of 6 Old 03-24-11, 06:52 PM
REW Author
JohnM's Avatar
John
Re: ?REW bug-must restart REW for input sound to register
Are there any error messages in the REW log files? Their location is shown in the About... box.
JohnM is offline
post #3 of 6 Old 03-26-11, 09:27 AM Thread Starter
I will check and get back in 3 days , am away from my REW installed computer at present.
Thanks
Richard
post #4 of 6 Old 04-02-11, 05:06 PM Thread Starter
Hello sorry was away longer that expected.
I checked my log files. I get an severe error warning on some log files but I think it's due to my clock settings being for august, 2004. When my date/time are correct I seem to get no error files. I cut and pasted two versions below: (there are no errors on any log files with the right dates)
filename:
roomeq_wizard4.log
contents:
Aug 28, 2004 1:07:32 AM roomeqwizard.RoomEQ_Wizard main
INFO: REW started
and
filename:
roomeq_wizard5.log
contents:
Aug 29, 2004 3:41:21 AM roomeqwizard.RoomEQ_Wizard main
INFO: REW started
Aug 29, 2004 3:41:48 AM roomeqwizard.dB A
SEVERE: Exception trying to open record device
{0}
javax.sound.sampled.LineUnavailableException: line with format PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian not supported.
at com.sun.media.sound.DirectAudioDevice$DirectDL.implOpen(Unknown Source)
at com.sun.media.sound.AbstractDataLine.open(Unknown Source)
at roomeqwizard.dB.L(Unknown Source)
at roomeqwizard.Q.actionPerformed(Unknown Source)
at javax.swing.JComboBox.fireActionEvent(Unknown Source)
at javax.swing.JComboBox.setSelectedItem(Unknown Source)
at javax.swing.JComboBox.setSelectedIndex(Unknown Source)
at roomeqwizard.dB.A(Unknown Source)
at roomeqwizard.dB.C(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at roomeqwizard.Q.A(Unknown Source)
at roomeqwizard.PB.H(Unknown Source)
at roomeqwizard.RoomEQ_Wizard.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at jexepackboot.run(Unknown Source)
at jexepackboot.boot(Unknown Source)
Today I am sure the date time are correct. However, I still get the problem of when I open up the SPL meter, I can use the meter once (I press the square button at the lower right with the red indicator light in it) and it works. The second time I press it the red light goes on but there is nothing registering on ther input meter, and the third time I press it the light won't go on. If I close the program and restart it, the cycle repeats. The same type of problem occurred when calibrating the sound card, the inputs would register initially, but didn't on second attempts , but worked fine if the program was restarted.
Also my first log file won't open (roomeq_wizard0.log), it says it is being used by another program?? Should I reinstall the program?
Richard
post #5 of 6 Old 04-02-11, 05:15 PM
REW Author
JohnM's Avatar
John
It is nothing to do with your date and time settings. Your soundcard's driver appears not to release the record line when REW closes it after making a measurement, when REW tries to reopen it for another measurement the response is that there is no input available, hence the logged error. You may find the ASIO driver behaves better, there should be a version of REW supporting ASIO around the end of the month.
JohnM is offline
post #6 of 6 Old 04-02-11, 07:17 PM Thread Starter
That's great John, I think I might be using Asio drivers, I chose that option in my recording software (where it really improved latency/speed issues in recording), so I'd be happy for that.
I'll be trying to figure out what I'm doing in the meantime, been reading lots threads trying to get some answers before I ask you guys too much stuff. Starting to come together, (I think).
Thanks for all.
Richard
?rew , bug-must , input , register , restart , sound
