First Graph, what now? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 2 Old 04-26-11, 02:30 PM Thread Starter
So I ran my first sweeps in REW with my RS meter, and it is pretty sloppy from about 52 or so through 80. I only ran the sweep from 10 to 100 and my fronts are crossed at 80. Because of this, I did not post the graph in conventional form up to 200hz. Hope that doesn't ruffle any feathers.
For this graph Audyssey was off, NO cal file was loaded for the RS meter, and I have bass boost enabled on my SW amp.
I have a single band PEQ on the SW amp to play with, any advice on what to try here? Thanks for any and all help.
FYI: the second plot (green) was with a bit more volume, but neither was as loud as recommended. (I'm a wuss with these sweeps)
bribowsky is offline
post #2 of 2 Old 04-26-11, 04:03 PM
Wayne A. Pflughaupt's Avatar
Re: First Graph, what now?
Welcome to the Forum, bri!
Here’s your graph. You can’t use a URL until after your fifth post, but you can upload your attachments using the “Go Advvanced, Manage Attachments” option.
For starters you need to get the volume up. It's practically down in the room noise. Not much we can recommend beyond that since you didn’t use the calibration file. That means your graph isn’t accurate below ~40 Hz. Not much use offering advice based on an inaccurate graph because the advice will be inaccurate as well.
graph , now?
