Which audio calibration file for mike to use - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 06-27-12, 12:40 PM Thread Starter
I got calibrated ECM8000 mike couple of months back from Cross-spectrum. I guess I need to go REW->Preferences->Preferences->Mic tab and point calibration file.
I have three narrow band, three one third octave and two polar response XL files. Which one do I need to browse to in calibration field of Mic tab?
I am starting compiling instructions to do bass ringing and water fall graphs for modal first. Please help me to get started on setting calibration file for Mike. Then I will do calibration for TASCAM 144 MKII
chinni123 is offline
post #2 of 11 Old 06-27-12, 01:05 PM
Will
Re: Which audio calibration file for mike to use
This may help chinni. See my posts 153
http://www.hometheatershack.com/foru...tml#post513930
Wull is offline
post #3 of 11 Old 06-27-12, 04:13 PM Thread Starter
Thanks for the link. I guess I can point to narrow_band_response_0_degree.frd that I got from cross spectrum. Since I am pointing microphone to ceiling, I am assuming 0 degrees is fine.
post #4 of 11 Old 06-27-12, 08:38 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
No, you’d use the 90° file for at-ceiling orientation. The 0° file would be for aiming towards the speaker, which is really best for frequency response measurements. More reading on the topic here .
post #5 of 11 Old 06-28-12, 12:08 AM
Will
If you only have the Basic ECM Mic, then like I have, use the Generic Cal file for 90 degree measurements. It's on this page, half way down.
http://www.hometheatershack.com/foru...oads-page.html
Wull is offline
post #6 of 11 Old 06-28-12, 05:10 PM
Hey Will,
Taking measurements with 90° mic orientation using a calibration file that was generated with on-axis (0°) orientation, such as our generic file, will give results showing sagging response at highest frequencies. If you want to take 90° measurements, you should use a calibration file created the same way.
post #7 of 11 Old 06-28-12, 05:21 PM
Will
Hey Will,
Ah, I thought this was Wayne. Is there a Generic Cal file for 90 degree?
Wull is offline
post #8 of 11 Old 06-29-12, 06:47 AM
What are you measuring (mains? subs?), and what are you trying to accomplish?
post #9 of 11 Old 06-29-12, 06:50 AM
Will
Mains and Sub together.
I have a 2 IB manifold system, one at the front and one at the back of the room, I want to see how these interact with my Main speakers.
Wull is offline
post #10 of 11 Old 06-29-12, 07:08 AM
Then all you’re really concerned about is perhaps 300-400 Hz and below. A 90° vs. 0° calibration file is only going be different above ~2-3 kHz; below that point they’re the same. Down in the range you’re interested in, you can use either calibration file with either mic orientation.
audio , calibration , file , mike
