Q Factor - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 12-13-12, 05:59 PM Thread Starter
Q Factor
Why are Q factors in EQs different from each manufacter?
I would think that e.g. Q 4.3, would be the same standard?
Thanks in advance
Phillips is offline
post #2 of 7 Old 12-14-12, 01:00 PM
REW Author
JohnM's Avatar
John
Re: Q Factor
Q is the ratio of centre frequency to bandwidth, but there are differences in how bandwidth is defined. Sometimes it is measured at the half gain point (e.g. at -4dB on a -8dB filter - REW uses this for its Generic EQ setting), sometimes at the -3dB points (but then what is the bandwidth of a -2dB filter?). Robert Bristow-Johnson wrote a paper that addresses this, see http://www.musicdsp.org/files/EQ-Coefficients.pdf
JohnM is offline
post #3 of 7 Old 12-15-12, 11:47 AM
Wayne Myers
Re: Q Factor
Phillips wrote: View Post
Thanks in advance
You are undoubtedly talking about band peak- and dip-type filters. Then there are questions like what is the Q for a shelving filter, or a low-pass or high-pass filter, and how is the shape of the filter response affected by Q. Sometimes there are different filter implementations possible. As John stated, it is not always as simple as we would like it to be, and it is not necessarily just manufacturers being contrary, but actually having multiple variables to deal with.
Edit: here is a link to a handy Q/bandwidth conversion calculator.
AudiocRaver is offline
post #4 of 7 Old 12-17-12, 03:39 AM Thread Starter
Re: Q Factor
JohnM wrote: View Post
Thanks John i will have a read
What would be the advantage between the Omnimic vs UMIK?
Phillips is offline
post #5 of 7 Old 12-17-12, 03:41 AM Thread Starter
Re: Q Factor
AudiocRaver wrote: View Post
Thank you i will download the calculator.
Phillips is offline
post #6 of 7 Old 12-17-12, 02:20 PM
REW Author
JohnM's Avatar
John
Re: Q Factor
Bit off-topic for this thread, but UMIK has SPL calibration data in the file so REW does not need SPL calibration when using UMIK. REW V5.01 beta 10 can also automatically recognise that UMIK is connected and configure itself correctly to use it for measurement.
JohnM is offline
post #7 of 7 Old 12-17-12, 02:21 PM
REW Author
JohnM's Avatar
John
Re: Q Factor
Bear in mind it is only useful for equalisers which define filters by the bandwidth at the -3dB points.
JohnM is offline
factor
