Roland Quad Capture - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 24 Old 01-12-13, 03:36 PM Thread Starter
Pending
Re: Roland Quad Capture
I really do appreciate all the help from you. I have since calibrated the sound card and I think I have my first readings, but am a bit puzzled...I did use the Quad Capture by the way and the Behringer mic to test that is recommended (ECM8000) and I have some pics of the responses I am getting. I just want to make sure I am doing this right because the mic responses look pretty flat to me. I do have monitoring off, so that's not it.Roland Quad Capture-test.jpg
I don't know if this how you insert pics. I did it as attachments..is that right?
wrtorn is offline
post #12 of 24 Old 01-12-13, 05:03 PM
REW Author
JohnM's Avatar
John
That measurement is of a loopback connection somewhere, either an external wired connection or an internal hardware or software monitoring path.
JohnM is offline
post #13 of 24 Old 01-12-13, 09:40 PM Thread Starter
Pending
Ok. Thank you...I'll keep trying. Maybe go back to the other sound card...I know it doesn't have monitoring.
wrtorn is offline
post #14 of 24 Old 01-13-13, 12:13 PM Thread Starter
Pending
made some more adjustments. It still looks like a loopback or monitoring prob to me??? I am starting to at least get a curve. I finally got the levels on the soundcard to -12db, and turned on/off ASIO monitoring, not sure exactly what to do there...here's more shots.
I don't know if this is any better.
wrtorn is offline
post #15 of 24 Old 01-13-13, 04:27 PM
REW Author
JohnM's Avatar
John
That is still a loopback/monitor path of some sort (way, way too clean for a room measurement). It rises at the low end because the inverse C weighting correction is turned on in REW (that is why there is a C-1 next to the value in the legend), you only need that if you are using an SPL meter as your input, it can be turned off by selecting "mic or Z weighted SPL meter" as the input type on the REW Mic/meter preferences tab. Do you have a loopback connection on the channel you are not using for measurement? Have you told REW to listen on the correct channel?
JohnM is offline
post #16 of 24 Old 01-13-13, 06:01 PM Thread Starter
Pending
Yeah, went through your help files again and I think I found the problem. Thank you for all your help thus far...trying again...
wrtorn is offline
post #17 of 24 Old 01-13-13, 06:23 PM Thread Starter
Pending
Is this better? I think I removed the problem. I also changed the test to go up to 20,000.
wrtorn is offline
post #18 of 24 Old 01-14-13, 06:17 AM
No, that's not better .
I'd suggest that you try your other soundcard .
The workings of this Roland card has ( obviously ) gotten you a bit flummoxed.
EarlK is offline
post #19 of 24 Old 01-14-13, 08:42 AM
I have Roland Octa-Capture, and have no difficulties on Windows XP machine. What OS are you using?
Front panel mix knob must be fully "playback".
Operating system mixer must have inputs muted in output mix.
Soundcard monitor mixer must have inputs turned all the way down.
Name:  input mixer.gif
Frequency response display zoom in on amplitude is simpler, clearer view of results for purposes here.
For loopback performance checking start with input sensitivity all the way down.
To see full performance use sweep 2Hz-24kHz 256k or 512k length for sample rate 48kHz.
For trained eyes, close inspection of impulse response can be very telling.
If you run a loopback as described and save measurement results as REW .mdat file and attach to post I will take a look at what you've got.
Andrew
Barleywater is offline
post #20 of 24 Old 01-14-13, 09:12 AM
Barleywater wrote: View Post
(i) Front panel mix knob must be fully "playback".
(ii) Operating system mixer must have inputs muted in output mix.
(iii) Soundcard monitor mixer must have inputs turned all the way down.
Andrew
Thanks ! Andrew for weighing in here .
With all the info that you've provided, hopefully our ( young ? ) friend will finally get a handle on properly managing his signal flow .
EarlK is offline
capture , combo ins , eq wizard , ins and outs , quad , roland
