Room Response - comments, please! - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 25 Old 04-06-13, 07:56 AM Thread Starter
John
Hi Folks,
I am re-visiting some REW room response plots I did a while ago and would appreciate any comments.
Please take a look at the attached plot. This is a stereo pair of Fostex FE167E full-range drivers each supplemented with an HiVi TN28 supertweeter. The response was measured using the Behringer ECM8000 microphone, which was located in the listener position. The room is 5.5m (L) x 3.5m (W) x 2.5m (H). The plot shows the LH channel (purple), RH channel (blue) and the averaged response (green). One-third octave smoothing has been used.
Despite the use of the TN28 supertweeters, HF roll-off is apparent beyond 3.5kHz. It is 3dB down at 6kHz and almost 8dB at 10kHz. I am also curious about the dip between 100Hz and 700Hz reaching a trough at 200Hz.
Would anyone care to shed light on these observations?
Thanks in advance.
JPC
jaypeecee is offline
post #2 of 25 Old 04-06-13, 08:55 AM
Wayne Myers
Re: Room Response - comments, please!
Is there a calibration curve in use for the mic? The HF rolloff looks like what one might find from the mic's natural response.
AudiocRaver is offline
post #3 of 25 Old 04-06-13, 09:28 AM
tonyvdb's Avatar
Tony
My understanding is that gentle falloff is natural. If you were to have a flat even line that stays even with the rest in those frequencies your ears would hurt particularly at higher volumes.
Home theater:
Living room system:
tonyvdb is offline
post #4 of 25 Old 04-06-13, 09:48 AM Thread Starter
John
AudiocRaver wrote: View Post
Hi AudiocRaver,
Thanks for your reply.
Yes, I used the calibration file that is available on this site.
Perhaps tonyvdb is correct? It just seems like a significant loss in HF but I'm really not sure. What kind of response is to be expected in the listening position? And what about that 200Hz trough?
JPC
post #5 of 25 Old 04-06-13, 09:54 AM Thread Starter
John
tonyvdb wrote: View Post
Hi tonyvdb,
Thanks for the reply.
Your point that "gentle falloff is natural" makes sense but is this a case of gentle falloff? As I said above, the response is 3dB down at 6kHz and almost 8dB at 10kHz. That seems a lot. Presumably, it would be different with headphones in that the HF would be at much the same level as the rest of the response?
JPC
post #6 of 25 Old 04-06-13, 09:57 AM
tonyvdb's Avatar
Tony
It seems a little bit much however even my EV 500 studio monitors exhibit the same roll off above 10k using the same mic your using. They are flat 35-18,000Hz
Home theater:
Living room system:
tonyvdb is offline
post #7 of 25 Old 04-06-13, 10:13 AM Thread Starter
John
Hi tonyvdb,
Thanks again.
When you say "They are flat 35-18,000Hz", is that in the listening position? If so, then what I'm seeing with my setup is very different. At 18kHz, the response is 16dB down at the listening position with my setup.
JPC
post #8 of 25 Old 04-06-13, 10:20 AM
tonyvdb's Avatar
Tony
Sorry, I meant to say the Specifications on the speakers are flat. My measured response with the sub is below.
Home theater:
Living room system:
tonyvdb is offline
post #9 of 25 Old 04-06-13, 10:50 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
jaypeecee wrote: View Post
Our calibration file is generic; you can’t be absolutely certain that your measured response is accurate without a custom calibration file. Mic orientation can make a difference too, whether or not you measured with it pointing at the speaker.
post #10 of 25 Old 04-06-13, 12:33 PM
Wayne Myers
As Wayne P. says, using the generic cal file could easily leave you with that amount of error.
As far as how flat you want it to be, it depends on your room. In a fairly live typical home theater or music listening room, the high-frequency buildup due to reflections will indeed seem harsh with a flat response. The rolloff you see is not too far from some suggested "target curves" for rooms like that, the intent being to help tame that harshness. A studio control room or mixing room, with well-damped acoustics, is generally tuned for flat response and it seems "just right" because of those acoustics.
comments , response , room
