Need Help (Focusrite Scarlett 8i6) - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 05-15-13, 07:35 AM Thread Starter
Smile Need Help (Focusrite Scarlett 8i6)
Hi all,
I am trying to callibrate my soundcard, but its harder to get it work than I thougt
My Hardware:
Soundcard = Focusrite Scarlett 8i6
Mic = Behringer ECM8000
Software:
Win 7 Ultimate 64 Bit
REW 5.01 Beta 17 build 2967
My Soundcard has the Software called MixControl where I can route the buse/channels. I have set DAW 1 to Loopback 1 (left) and DAW 2 to Loop Back 2 (right). See attachement file for more information.
Then I set up the preferences in REW5 like in the attachement file. I also can hear the reference tone.
But when I finfish the callibration, the graph is only a straight line (seee attachement). Do I have the perfect soundcard or what am I doing wrong?
Thanks for your help
nino8008 is offline
post #2 of 7 Old 05-15-13, 08:42 AM
Re: Need Help (Focusrite Scarlett 8i6)
You really need the help of someone who is fully conversant about the ( Ins & Outs ) of MixControl .
You'll find that these software based mixers ( like MixControl ) are major stumbling blocking for newbs trying to get signal into ( & out of ) REW .
- It escapes ( most non-musicians ) that these mixers are meant to create heaphone mixes for players to monitor existing tracks ( to play along with while they are recording ) .
Having said all that, it's obvious ( to me ) that you have setup ( this software based mixer ) incorrectly .
For instance ,
INPUTS:
REW's inputs need to be connected to the hardware based ( choices seen within Focusrites' MixControl ).
- That would appear to be named "Anlg input 1" & "Anlg input 2" .
- The ( MixControl ) faders should ( most likely ) be kept down & off ( since usually , typically those input faders only effect the levels sent to the output of this type of monitoring mixer ) .
OUTPUTS:
According to the screenshot of your MixControl setup, you should be discovering REW's output signals appearing at ( your Scarlett 8i6 ) analog outputs, 1 & 2 .
Creating a LoopBack ( for calibrating your soundcard )
- These loopbacks must be made using a physical cable that connects your soundcards output to the input channel ( that'll ultimately ) be used with your test mic ( & reference timing chnl ) .
- You've ( unfortunately ) become confused by the inclusion of a ( software based ) loopback circuit found within MixControl ( & mistakenly utilized it within your setup ). Don't use it ( that's why you're measurements are currently only flatlines ) .
EarlK is offline
post #3 of 7 Old 05-15-13, 11:09 AM Thread Starter
Thanks a lot for your reply!
Although my english is not soo good, I try to understand what you mean.
Well now I bought that missing cable and connect it as you can see in picture 1 (yellow circles).
In REW for input I cannot choose 'Anlg 1 input' or 'Anlg 2 input' (see picture 2 & 3 for input & output).
So I set the Output of REW to '1: Mon 1' and the Input to '3: Line 3'. And now I had to turn up the volume knob to the maximum to reach the level of -15dB (see picture 4). I hope I am doing right
The Headroom is about 12dB (see picture 5).
And last but not least I got the expected graph, I hope it so at least. Can you check the .mdat File if everything I did is correct? Thanks a lot for your help
Attached Files scarlett_8i6.mdat (3.65 MB)
nino8008 is offline
post #4 of 7 Old 05-15-13, 11:32 AM
Yes, your setup is getting better now that you aren't using the builtin LoopBack circuit . .
- You ( & 1 ) can see from your current measurement (.mdat file ) that the line-out to line-in measurement doesn't really need a correction file .
- The problem here is that actual REW testing requires the use of a mic pre-amp / therefore this line-out to line-in measurement is somewhat moot ( misleading & beside the point ).
- ( & ) Typically line level circuitry is "flatter" than the circuitry found in a pre-amp .
- ( Therefore ), I would chose "1: Mic 1" as the input channel for a new loopback measurement ( since this is the actual mic pre-amp that will get used ) .
- Use the same output that you are currently using .
EarlK is offline
post #5 of 7 Old 05-16-13, 08:32 AM Thread Starter
Thanks you so much, now everything is clear and its working
Tomorrow I will receive the basstraps and acoustic foams so I hope there will be some measurable improvements in my homestudio
nino8008 is offline
post #6 of 7 Old 05-16-13, 05:03 PM
REW Author
JohnM's Avatar
John
Good to see Earl has got you going, I'll delete the posts in the V5 beta thread.
JohnM is offline
post #7 of 7 Old 05-17-13, 09:57 AM Thread Starter
@JohnM: Yes please, delete them thanks
nino8008 is offline
8i6 , focusrite , scarlett
