OmniMic and REW - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 06-28-13, 03:06 PM Thread Starter
OmniMic and REW
Can I use my OmniMic with REW ? I can get the mic files from PE......
Kgveteran is offline
post #2 of 9 Old 06-28-13, 03:16 PM
Wayne Myers
Re: OmniMic and REW
Yes, your cal file can be imported directly into REW on the Preferences-Mic/Meter page.
AudiocRaver is offline
post #3 of 9 Old 06-28-13, 06:53 PM
Re: OmniMic and REW
Do not calibrate the laptops sound card.
Also the Sens Factor (SPL) on top of the mics calibration file might not be correct, but calibrate it with the Omnimic SPL readings to confirm.
REW most likely will ask if you:
Want to use Omnimic, click yes
Then ask do you have a mic calibration file, click yes then find and load.
You are pretty much ready to go.
Hope this helps
Phillips is offline
post #4 of 9 Old 06-28-13, 09:01 PM Thread Starter
Re: OmniMic and REW
Thanx guys, I usually know enough to get myself into trouble. I will give this a try, im cautiously optimistic.....
post #5 of 9 Old 05-10-14, 05:44 PM
Re: OmniMic and REW
im trying to do this right now but cant find the cal file. Im not too computer savvy. anyone know the type of file it is?
ht-core is offline
post #6 of 9 Old 05-10-14, 06:52 PM
Re: OmniMic and REW
ht-core wrote: View Post
The file extension will be .omni
If you can't find it on your laptop download it again and watch where it goes to, will go to the place were you should be looking for it. If so delete one of them.
Setup a new folder called REW and put all REW related files in this folder, alot to easier to control.
1. Plug the mic into the laptops USB port.
2. Open REW, the program will ask
3. REW will ask if you want to use the Omnimic click yes
4. Then the program will ask to load the calibration file, click yes and then pick the .omni file and load.
5. Done
Phillips is offline
post #7 of 9 Old 05-10-14, 08:43 PM
Re: OmniMic and REW
It's kinda funny how the file is saved. It's to a website that has text. So I copied the text and made a new text file and loaded it to the program. Is it OK how I did that?
ht-core is offline
post #8 of 9 Old 05-11-14, 11:17 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: OmniMic and REW
Yup, that’ll do it.
post #9 of 9 Old 05-11-14, 12:46 PM
Re: OmniMic and REW
Nice! I'm glad it's that easy. Next step is sub calibration correct?
ht-core is offline
omnimic , rew
