Blending response of Sub and Mains - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 07-25-13, 04:35 PM Thread Starter
Rog
HI Everyone,
I've hit a point where I could use some help.
Here's the equipment I'm using:
Behrenger 502
Dayton Audio EMM-6 microphone with calibration file from Cross Spectrum
Windows 8 laptop interfacing to a Creative X-FI external sound card.
Behrenger 1124P
VTF3 - Mark 4 Sub
B&W 603 Mains Crossed over at 80 HZ
Sunfire Ultimate Reciver II
I am equalizing my new sub and I'm trying to use the "lean and mean" house curve outlined in this thread http://www.hometheatershack.com/foru...e-options.html
Here's the curve:
20 10
22 9
25 8
28 7
31.5 6
36 5
40 4
45 3
50 2
56 1
63 0
I've gotten close a couple of times, and overall I like the resulting sound that I get when I listen to music. But, I always seem to get stuck at the point where I try to integrate the response of the mains and the sub together.
Here's the baseline I'm dealing with:
When I build the filters, I tell it to use filters from 20 - 60 HZ, which corresponds to the house curve. The sub response follows the curve pretty good as shown below:
Where I run into trouble is when I try to get the response of the subs and mains to blend together smoothly. I know that the response from 60 - 90 is way too high, and that what I want to get to is a response that continues as with the red line that I added below:
I'm stumped as what's the best way to get this done. I've tried several different things, including adding filters out into 80 + hz range, and I don't seem to be able to get the response that I need. Whenever I do try to do that, I don't have any idea how to set the filters, and end up using trial and error because the subs and mains are both contributing to the overall response, but I can only equalize the sub. (Don't know if that made any sense or not)
Here's 15 - 200 hz response for the sub and left main together taken from a full range sweep:
I don't know if my assumptions about how to approach this are correct or not. If I'm way off base somewhere, please let me know and I'll reset. Are there some steps that I can follow to get this resolved ?
I'm going to attach the mdat and req files for these measurements. Here's the mdat: Test 8 measurements.mdat
Here's the REQ file: Test 8 - Limits 20 - 60.req
The mdat is a group of three measurements, and includes a full range sweep of the sub and left main.
Thanks in advance for any insight you can provide.
Rog
rogerv is offline
post #2 of 6 Old 07-25-13, 08:04 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Blending response of Sub and Mains
rogerv wrote: View Post
Hey Roger,
I’d first suggest finding a location for the sub that gets a better baseline response. That graph’s not the best candidate for reasonable equalization.
Beyond that, I’d suggest equalizing your house curve all the down to the crossover point, even if you want response to level out at 60 Hz. At that point, it should just be a matter of adjusting the sub level relative to the mains.
post #3 of 6 Old 07-26-13, 10:10 AM Thread Starter
Rog
Hi Wayne,
Thanks for the reply. I don' know if I've got a better place for the sub in the room. I spent a lot of time prior to this trying to find a spot that didn't have major suckouts or humps in it to start with. I eliminated lots of positions that had suckouts in them in the 40-80 hz range. What is there about the starting point that I should try and improve ? The sub has lots of different settings that change the characteristics of its response. I could modify these to get a better starting point, but don't know what to shoot for.
Unfortunately, the room is 14 ft. by 15 ft. by 8 ft, which is almost square. In addition, the mains alone generate a huge 15 db peak around 40 HZ. that seems independent of crossover settings. When I went through this a couple of years ago, no one could figure out why that behavior occurred.
I'll keep banging on this.
Thanks again,
Rog
rogerv is offline
post #4 of 6 Old 07-27-13, 11:05 AM
REW Author
JohnM's Avatar
John
Doesn't look like there was any output from the left main in your 'sub and left main' measurement. Basic problem is your target level is too low, and the low end of the sub output doesn't have enough level to support 10 dB more output at 20 Hz than at 63 Hz. Try removing the house curve for the moment, set the target level to 85 dB and generate filters for the range up to at least 100 Hz.
JohnM is offline
post #5 of 6 Old 07-27-13, 12:33 PM Thread Starter
Rog
John,
Thanks for the reply. I'm pretty sure you have me on the right track now. Here's what did it for me:
JohnM wrote: View Post
This sub has two adjustable parameters (called "EQU" and "Q") that affect the overall shape of its output. These settings really give a lot of flexibility for a starting point. The previous baseline was using "EQU2" on the sub. I went back and did some new baselines using EQU1 which has more output around 20 hz. Here's the starting point using EQU 1.
This starting point doesn't have the sag around 20 HZ and below that you pointed out and should support a 10 DB difference between 20 and 63.
I really can't remember how I ended up with EQU 2 rather than 1. I know that I've gone through lots and lots of combinations and iterations, so I may have just flipped the wrong switch at the wrong time. Anyway, I'm going to reset with one of these as the new starting point and try again.
Rog
I just realized that the graphs that I posted were with equalization added, not baseline. Aargh. I'll post corrected baselines.
rogerv is offline
post #6 of 6 Old 07-27-13, 01:16 PM Thread Starter
Rog
I thought I'd better post a separate correction message rather than try and change the original. The graphs I posted in the previous message were with equlization added. I forgot to bypass the equalizer
Anyway, here are the correct baseline measurements:
Rog
rogerv is offline
blending , mains , response
