Back In The Saddle Again - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 24 Old 08-23-13, 07:29 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Back In The Saddle Again
I’d say they’re about the same in that regard. BTW, some rude person scribbled all over the faces of your pictures!
post #12 of 24 Old 08-23-13, 08:29 PM Thread Starter
weverb's Avatar
weverb
young people and their graffiti!
Ok. I will have to see what I can do filter wise to address both. I did try a couple filters today for the 650 range. I did not take any measurements. Just listened at my normal listening levels and I didn't hear anything bad. Nor did the clip lights blink on the eq. Need to verify the new filters with some measurements later.
System 1: Pioneer SX-950, CT-F9191, modded CA 651P, PL-707 w/DV Karat 23RS MKII, RH-65, RG-1, SR-202, Monitor 10/HE-500 hp's
System 2: Laptop, M2tech Young, Oppo 83, JVC QL-A75 w/DV XX2 MKI, DIY phono preamp, Simaudio i5.3, Dali Mentor 2's
weverb is offline
post #13 of 24 Old 08-24-13, 10:38 AM
weverb wrote: View Post
Any clipping will probably come first from the amplifier as it reaches its limits at the boosted frequencies, not the equalizer.
post #14 of 24 Old 08-24-13, 11:23 AM Thread Starter
weverb's Avatar
weverb
Yea, feelin' a little stupid after that comment. I should have known better. Need to check to see if there is any indicator for clipping on the integrated amp or not. The amp did not feel any warmer than usual either.
weverb is offline
post #15 of 24 Old 08-28-13, 09:59 PM Thread Starter
weverb's Avatar
weverb
Just a small non-REW update. Working on setting up and using the Sabine's contact closure switch on the back of the unit. This will let me switch between different presets without having to use the software. Just the touch of a button.
I already tested one button with a multimeter and continuity. I then tested the adapter and button with the actual unit. The preset was verified to switch with just pressing the button. Just need to finish wiring and making it look pretty.
weverb is offline
post #16 of 24 Old 09-02-13, 06:53 PM Thread Starter
weverb's Avatar
weverb
Ok, did a couple more measurements yesterday which raised a question? Which is more important, the individual speakers' response graph or the two combined? I ask because I was able to adjust the dip at around 660 Hz on each speaker's response, but when combined the dip did not change.
weverb is offline
post #17 of 24 Old 09-04-13, 07:10 PM Thread Starter
weverb's Avatar
weverb
No thoughts? Wouldn't the two combine only effect the center image and mono recordings?
weverb is offline
post #18 of 24 Old 09-05-13, 05:19 AM
Dale Rasco's Avatar
Dale Rasco
It sounds like there is a reflection point that may need to be addressed with acoustic treatments versus eq. I would try putting the frequency back to what it was and then run a series of sweeps a put large objects, such as a person, in different places along the way and see what is affected on each sweep. While this is by no means a scientific process it is a quick way to identify areas that are susceptible to dead spots.
Dale Rasco
“Opportunity is missed by most people because it is dressed in overalls and looks like work." -Thomas A. Edison
Dale Rasco and
Dale Rasco is offline
post #19 of 24 Old 09-05-13, 06:09 AM Thread Starter
weverb's Avatar
weverb
Thanks Dale, but as stated in the first post, no room for treatment panels.
weverb is offline
post #20 of 24 Old 09-09-13, 08:47 PM
It would be surprising if both speakers individually had the dip at 660, since the room layout you gave us in the opening post shows non-symmetrical placement in relation to the room boundaries. It would be enlightening to see measurements of each speaker separately, but regardless, if there was no change in response after equalizing both speakers at 660 Hz, then there’s nothing you can do about it, short of re-locating the speakers.
back , saddle
