Back In The Saddle Again - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 24 Old 08-21-13, 10:35 AM Thread Starter
weverb's Avatar
weverb
Or should I say Part Deux! Due to life's roller coaster ride of events, it has been almost three years since my last post on here. My home theater is long gone but I have started back with a "simple" two channel set up in my bedroom (12' x 14' x 8'). I was enjoying how it sounded but started thinking about ways to make improvements. Then I remembered I still had all my measurement gear (calibrated ECM8000, 802, and UCA202).
The first attachment is a rough layout of the room. As you can see, there is no room for sound treatment panels. So that option is out. There is a floor lamp in the top right corner, two closets, and an office out cove in between. There are heavy curtains behind the bed running the width of the room. There is also a curtain closing off the office space. After not being able to add sound panels, then I started reviewing my old information on parametric eq's. Being applied to mains or bookshelves, the unit needed to be quiet and very flexible. I look at units from Ashly, Symetrix, Klark, etc. I wound up picking up a Sabine GRQ 3102S.
Once everything was temporarily connected and verified to not add any noise, I fired up REW. I am still using an older version (4.x?). So I opened up the REW help files and started the process all over again. I started with recalibrating the soundcard to include the DAC. Sorry I did not save a graph but it looked just like the very first example. After verifying my levels were good, I decided to see what was going on in the room with no sound.
The next two attachments show the RTA of the noisefloor in the room. It was interesting to see the very low end fluctuate so much with the air on and off.
weverb is offline
post #2 of 24 Old 08-21-13, 10:44 AM Thread Starter
weverb's Avatar
weverb
Re: Back In The Saddle Again
After playing with the RTA, I was ready to proceed with measurements. I only have two listening positions. The first can be seen in the layout. It is the red outline of the chair. I basically move the chair from the wall and in front of the bed. This is my "critical" or primary listening spot. The second is 6' behind it sitting on the bed and relaxing.
After taking many, many, many measurements I was able to get a good before and after graph. The first attachement shows the results of no eq (green) versus adding eq (red). The second shows how I tried to follow a house curve for the room. I was not focused on staying on the line but more so following the trend. It is far from perfect and still a work in progress. I am still listening and evaluating. It is very different from before and taking some getting use to.
The last two attachments show the before and after waterfall plots. Hope they are correct. It has been a long time since I have done any of this.
weverb is offline
post #3 of 24 Old 08-21-13, 10:46 AM Thread Starter
weverb's Avatar
weverb
I have roughly started on the second seating position to just get it started. Here is the graph results from that.
Was very surprised to see very little change in the upper frequencies even with moving back 6'.
weverb is offline
post #4 of 24 Old 08-21-13, 11:10 AM Thread Starter
weverb's Avatar
weverb
I forgot to add this picture of the speakers (Dali Mentor 2's). As you can see, relocating them is not an option too.
weverb is offline
post #5 of 24 Old 08-21-13, 07:51 PM Thread Starter
weverb's Avatar
weverb
Going back and reading the thread on Minimal Eq, there is a lot about cutting filters and no mention about boosting filters. For some reason I remember trying to avoid boosting filters. Is there a "rule" for them too? Something like only +3dB < 80Hz, +6dB < 500Hz, and only +9dB > 500Hz? I see in one example where there is a gain of +9dB at 50Hz and +7 dB at 63Hz. And obviously nothing narrow like a notch filter.
weverb is offline
post #6 of 24 Old 08-21-13, 08:16 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Nice to see you back weverb!
Not sure you’re talking about with the cut-only thing in the Minimal EQ article. I posted EQ settings for the BFD everywhere, using filters boosted as much as 12 dB. Basically there is no rule for boosting. That stuff is mainly floated by people who have little hands-on experience with equalizers. If they did, they’d know that boosting or cutting is academic. In the end, virtually any equalizing ends up taxing headroom, so you have to have it to spare going in, as discussed here.
post #7 of 24 Old 08-21-13, 08:51 PM Thread Starter
weverb's Avatar
weverb
Hey Wayne!
Its been too long since our discussions and research on parametric eq's.
I was referring to your section on "How to recognize perfectly useless filters" where you mention to avoid filters of only 2-3dB and very narrow bandwidth. It seemed like you were only talking about cutting filters.
So how does one know how much headroom is available? In your link, you mention low volumes and subs. Well, these are bookshelf speakers running full range and at low volumes. I cannot recall a time of having the volume past 1/2 way. Is it less taxing on higher frequencies versus lower. I know it takes a lot of power to boost low frequencies by only 3dB.
What has me asking are those two nasty dips (~120 and ~650Hz.). I am wondering if I can add a little boost to each speaker to help those areas. Obviously, if they are regions that are being sucked out by the room then no eq is going to help.
System 1: Pioneer SX-950, CT-F9191, modded CA 651P, PL-707 w/DV Karat 23RS MKII, RH-65, RG-1, SR-202, Monitor 10/HE-500 hp's
System 2: Laptop, M2tech Young, Oppo 83, JVC QL-A75 w/DV XX2 MKI, DIY phono preamp, Simaudio i5.3, Dali Mentor 2's
weverb is offline
post #8 of 24 Old 08-22-13, 05:27 PM
Hey weverb,
There is so much that accounts for how much headroom one has available that it’s difficult to determine it – things like the speaker’s efficiency, how much boost is applied, and where, etc.
The headroom issue extends to any frequency, but a full-range speaker boosted at bass frequencies would make you run out of headroom sooner, since bass demands more power to begin with. However, often bass clipping isn’t readily audible, so you might actually notice distortion in the upper frequencies before the bass.
In your situation, all you can do is try boosting the problematic areas and see what happens. You’ll hear clipping specifically in the frequency range where you applied the boost when you run out of headroom. If that occurs, you’d need to dial the gain down on that filter.
post #9 of 24 Old 08-22-13, 08:10 PM Thread Starter
weverb's Avatar
weverb
Thanks Wayne. I always find our conversations very educational. I figured like most things with audio, it was going to come down to trial and error. Both dips look about the same. I guess I will just pick one to try.
weverb is offline
post #10 of 24 Old 08-23-13, 11:45 AM Thread Starter
weverb's Avatar
weverb
Silly question(s) I am sure, but does one of those dips have more musical information than the other? Basically, correcting which one will have the most audible impact?
weverb is offline
back , saddle
