Another dumb cabling question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 02-13-14, 08:33 PM Thread Starter
adproducer
Question Another dumb cabling question
I'm almost ready to begin testing my newly-treated room, but I'm confused about the REW Interconnect diagram using an SPL Meter. I have a 2.1 monitoring system (TAPCO), and the crossover control is on the subwoofer. The diagram shows a processor sub-out going to an EQ box then to the subwoofer. I'm running a G5 and a PreSonus Firebox interface, and I don't think I can breakout a signal as shown. My current signal path is G5 - Firebox - external EQ box - subwoofer input - crossover feeds out to monitors. Can I still use REW with my signal path as is? If not, would it be possible to create the correct path w/my rig?
And I apologize for the rank newbie question, M8s.
Cheers!
adrianproduces is offline
post #2 of 5 Old 02-13-14, 09:42 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Another dumb cabling question
Welcome to the Forum, Adrian!
I don’t know what a G5 is, but if you can get a signal from your computer to your speaker system (sounds like it’s active?), that you can hear music through, then it will work for REW.
post #3 of 5 Old 02-14-14, 09:22 AM
adrianproduces wrote: View Post
Cheers!
I'll be very curious to see if you can get an input signal from that soundcard to show up within REW's preferences window .
The G5 ( PPC chipset from older Macs ) should allow you to run REW & execute all the programs file parsing commands ( I've tried this with a G4 Mac Mini running OSX 10.4 & 10.5 , using files obtained from running REW on my PC ) .
The hiccup I've encountered is that I can't get any input to show ( & maybe even output ?? ) within the REW preferences box ( & this is after trying all the Java-Mac suggested work-arounds .
EarlK is offline
post #4 of 5 Old 02-15-14, 04:20 AM
I was able to get REW to work with a FireBox... in fact that's what I used when figuring out the workaround... Not a G5 tho, so that could mess everything up.
HifiZine is offline
post #5 of 5 Old 02-18-14, 11:37 AM Thread Starter
adproducer
Just about to begin the process. I'll update and ask further questions as needed. Much thanks for your replies. Cheers!
cabling , connection? , dumb , question , signal path , subwoofer
